can't connect my bluetooth anymore - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
Old 05-18-2012, 06:53 PM   #1 (permalink)
View riderx's Photo Gallery
I have a 2011 HL and had my phone connected but all of a sudden it does not work. i can see phone calls coming in, but when i try to answer it hangs up. same thing with outgoing calls. i can dial out but hangs up in a matter of seconds. i tried deleting the phone and then re entering it and same thing. anyone else experiencing this? any suggestions will be helpful!
riderx is offline   Reply With Quote
Old 05-18-2012, 08:16 PM   #2 (permalink)
View TheBum's Photo Gallery
Did you try rebooting the phone?
TheBum is offline   Reply With Quote
Old 05-18-2012, 09:17 PM   #3 (permalink)
I've even tried to pair another phone to no avail. do you know of a way to reset the bluetooth system?
Old 05-18-2012, 09:49 PM   #4 (permalink)
There's a menu item listed in the 2012 manual for resetting the system. It's listed as a voice command: "Setup" then "System Setup" then "Reset Setting". I've never tried it. I would assume the 2011 would be similar.
Old 05-22-2012, 01:53 AM   #5 (permalink)
I tried doing that and there is no system setup on the 2011. only phone setup and there is no option for a reset. I hope this is covered by some kind of warranty. very frustrated!
Old 05-22-2012, 07:59 AM   #6 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $1007100
View 05Moose's Photo Gallery
Are you still under the factory warranty? If so, it's covered. The first thing they'll suggest is that you try pairing a different phone to eliminate your phone as the problem. Sounds like to already did that test. Been there, done that recently with a non-Nav unit where our bluetooth had problems. Thus the reason we're on radio #3.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline   Reply With Quote
Old 05-22-2012, 08:11 AM   #7 (permalink)
View NoMan's Photo Gallery
I had a similar issue and had to delete the "HANDSFREE" bluetooth from my phone and then re-pair it as a new device. Annoying, but it worked. Hope this helps.
NoMan is offline   Reply With Quote
Old 05-22-2012, 10:43 AM   #8 (permalink)
I just had mine completely forget the pairing. I rebooted the phone while the system was on and couldn't get a connection afterward. When I tried to select a BT device, the system said none were paired. Maybe in my attempts at a connection, I accidentally caused the pairing to be deleted. I wish there was a kill switch to power-cycle BT without turning off the ignition.
Old 05-23-2012, 01:18 PM   #9 (permalink)
any idea how long a warranty is good for? i bought my HL last march. My HL has no NAV either and was wondering what is radio #3?
Old 05-23-2012, 02:03 PM   #10 (permalink)
Look again. I had a hard time finding it on my 2012 HL and finally discovered the secret after doing a search here.
1. With the audio system set to a mode other than BT Audio, press the talk switch.
2. Say "Setup".
3. This is where the trick comes in. Instead of speaking the next command, go to the tuner knob on the audio system and cycle through the options. You should see System Setup. There is no corresponding voice command. Press the tuner knob with that option displayed.
4. Cycle through the next group of options with the knob and you should find "Reset Settings". If you press the tuner knob while that option is displayed, the system will reinitialize.
Old 05-23-2012, 02:52 PM   #11 (permalink)
Senior TN Member
summerwind's Avatar
Gameroom cash: $641380
View summerwind's Photo Gallery
Might try this to solve my gremlin
I press the talk switch and say "dial by name" instead of saying " press the talk switch and say a name" it just randomly selects a stored name
Does the system reset wipe all data that is stored (ie you have to re-pair phone, re-enter phone numbers after this step)
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 05-23-2012, 06:14 PM   #12 (permalink)
I didn't complete that last step, but I suspect it will wipe everything.
Old 05-23-2012, 07:23 PM   #13 (permalink)
I just got brave and pushed the knob. The nice lady told me what would be erased and it does include phone book entries. I then chickened out and cancelled.
Old 05-25-2012, 12:26 AM   #14 (permalink)
I'm at a loss. I had no choice and reset the system but to no avail. i paired my phone once again and tried to make a call and the bluetooth just turns off. don't know what to do anymore
Old 05-25-2012, 08:25 AM   #15 (permalink)
Sounds like a trip to the dealership is in order.
