2013 "Display Audio" Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
Old 01-06-2013, 08:54 AM   #1 (permalink)
2013 Highlander
View rogish's Photo Gallery
I'm replacing the factory "Display Audio" head unit with a Kenwood DNX6990HD. The last challenge I'm facing is integrating the factory backup camera.
I've spent a lot of time reviewing the following thread, and made a voltage converter as outlined here: HOW TO: Using the factory rear view camera with aftermarket stereo. However, I don't have a reference as to the color/pin # of the wires that I need to splice for a 2013 Highlander.
Does anyone have this info available?
Thanks,
Steve
rogish is offline   Reply With Quote
Old 01-06-2013, 12:38 PM   #2 (permalink)
Gameroom cash: $110750
View cutienoua's Photo Gallery
I can t help with that info
As a last resort you can use aftermarket camera it will perform better
Mine is 170 degrees wide
Are you going to replace other audio components ?
cutienoua is online now   Reply With Quote
Old 01-06-2013, 01:06 PM   #3 (permalink)
2013 Highlander
Yes, door speakers, and a sub. I don't see where replacing the camera provides a lot of value for me; perhaps in the future that will change. My main concern today is to get the new head unit in, as I'm not happy with wires/antenna on the dash (SiriusXM), and I'd like to use in-dash NAV on a trip scheduled in a couple of weeks. If I can't figure out the backup camera in the next few days, I'll have to live without it until I return.
Steve
Old 01-06-2013, 08:40 PM   #4 (permalink)
2013 Highlander
Has anyone replaced their 2013 head unit? I just checked, the width of the factory unit's faceplate is 7 13/16". Other than the skinny trim ring that came with the Kenwood DNX6990, I don't have anything that is going to bridge that gap (new HU is 7"). The kit that Crutchfield included is obviously for pre-2013 Highlanders.
Steve
Old 01-06-2013, 08:46 PM   #5 (permalink)
cartoys or similar shops have filler
or you could just get creative !
like these guys:
http://www.diymobileaudio.com/forum/...el-filler.html
Old 01-07-2013, 08:41 AM   #6 (permalink)
2013 Highlander
like these guys:
Looks great; but really commits you to leaving the aftermarket radio in the car when you sell it. Plus you'd have to match/repaint the plastic. My plan is to install with a gap for now and wait for a kit, or fabricate a couple of plastic rectangles that I can hot glue to the fascia, then snap off when the kit arrives (or when I reinstall the factory H/U).
Steve
Old 01-07-2013, 10:36 AM   #7 (permalink)
Release the Mods!
sweeneyp's Avatar
Gameroom cash: $921336
View sweeneyp's Photo Gallery
So crutchfield sent you the dash kit for the 08-12's? Can you just remove the 2013's outer "shell" so it leaves that large gap so the kit you got fits? I bet toyota is still using the same dash as the earlier years, so I bet the shell pops out like the older radio's.
2008 FWD Highlander Limited<---Short---Modification List---Full--->CarDomain
sweeneyp is offline   Reply With Quote
Old 01-07-2013, 11:52 AM   #8 (permalink)
2013 Highlander
The '13 and '12 dashes are similar, and likely have all the same dimensions, screw holes, etc; however, not similar enough that parts are interchangeable.
Stock H/U (note hazard button and pass airbag info where legacy knobs used to be):
Legacy bracket from Crutchfield:
Height/Width 4" x 7 13/16" vs 4" x 7":
Kenwood DNX6990 bracket:
I found another '13 owner (jsirboo) that has swapped his H/U, and he's got it installed with gaps on either side to the radio, patiently waiting for one of the kit manufacturers to make them.
Crutchfield doesn't have any answers right now (I forwarded them these photos earlier today), so I'll just install the new H/U with gaps for now...
Steve
Old 01-07-2013, 02:50 PM   #9 (permalink)
I would pay extra to buy a brand new vehicle with standard din opening and power connector , standard size speakers.
so we don't have to go thru this every time you want to swap parts.
Likely will never happen!
Old 01-07-2013, 03:32 PM   #10 (permalink)
2013 Highlander
The other TN member and '13 HL owner, jsirboo (http://www.toyotanation.com/forum/287558-jsirboo.html), also reminded me that I'll need an AM/FM antenna adapter. Crutchfield carries it (Metra 40-LX11 - Item# 12040LX11), and provides it free of charge when you purchase a head unit for a qualifying vehicle. I wasn't aware of the need (nor was Crutchfield), as it wasn't listed in the 'What fits my car" section. I contacted them, and they're sending one for free (I bought my H/U from them last week).
Steve
Old 01-07-2013, 06:35 PM   #11 (permalink)
I was reading the reviews for your unit and it looks like you have to tap Agree every time you start the vehicle!
Wow ! this is the thing I hate the most. In my previous highlander I was able to buy a module to bypass that screen
I do like Garmin nav, I use it as an app with iphone 5
my setup
http://www.flickr.com/photos/8005880...n/photostream/
Old 01-07-2013, 07:05 PM   #12 (permalink)
2013 Highlander
Are you referring to the Kenwood DNX6990, or Toyota factory NAV? My '13 HL doesn't have factory NAV, but my wife's Avalon does. It does prompt you to hit 'Agree' on each start, but only for the first few seconds. If you ignore, it goes right to the map.
Steve
Old 01-07-2013, 07:11 PM   #13 (permalink)
Kenwood
Sorry I forgot to mention
Old 01-07-2013, 11:44 PM   #14 (permalink)
Release the Mods!
sweeneyp's Avatar
Oh, oops. Forgot about those (and that small panel that sits below the headunit on the 08-12).
Old 01-08-2013, 12:47 PM   #15 (permalink)
My next car radio must have Air play !
And a nice hi definition screen ! smile
But,than again they will lock out video while moving!
this is not one of them,but still nice:
http://www.engadget.com/2013/01/08/a...ora/#continued
