Horn replacement - 2013 Toyota Highlander - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
post #1 of 28 Old 08-20-2013, 11:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Looking to replace horns with louder FIAMMs. What is the best way to wire to a positive and negative terminals. Connection on truck has two gray wires. Thank you.
cd678 is offline
post #2 of 28 Old 08-20-2013, 11:32 PM
Senior TN Member
El Loco VG's Avatar
Quoted: 5 Post(s)
I'm not sure if this is what you mean but the single wire on each harness is a positive daisy chain and the negative comes from the bolt securing it to the chassis making an earth ground.
El Loco VG is offline
post #3 of 28 Old 08-20-2013, 11:35 PM
Senior TN Member
El Loco VG's Avatar
Quoted: 5 Post(s)
Reading it again your positive is the harness if you need a ground on the horn run a jumper wire from the chassis bolt to your horn neg terminal use one of the circle crimp heads (can't remember name)
post #4 of 28 Old 08-20-2013, 11:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
@El Loco - so are you saying that the two gray wires hooked up to a single male connector into female connection at the horn, are positive?
cd678 is offline
post #5 of 28 Old 08-20-2013, 11:43 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
El Loco just saw your second reply, that makes sense - thanks very much.
cd678 is offline
post #6 of 28 Old 08-21-2013, 05:27 AM
Senior TN Member
El Loco VG's Avatar
Quoted: 5 Post(s)
N.p. I will soon be swapping mine out as well. I had a rav4 that sounded even Girlier than this but my Camry had the nice deep sounding horn go figure.
post #7 of 28 Old 08-21-2013, 06:39 AM
RectangleAmericaMegaphone
Quoted: 0 Post(s)
FWIW Lexus IS300 horns bolt in with no modification and are a huge improvement in sound. Should be cheap used.
9volt is offline
post #8 of 28 Old 08-21-2013, 07:04 AM
Senior TN Member
summerwind's Avatar
Quoted: 13 Post(s)
I bought Camry horns for my HL
Easy swap they use the same horn relay amperage so you don't need to do major mods
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline
post #9 of 28 Old 08-21-2013, 11:16 AM
MikeyD25's Avatar
Quoted: 46 Post(s)
There's a STICKY for that titled DAMN BEEP-BEEP HORN NO MORE.
In memoriam NYPD DAOS / NYS OIG #77
'15 RAV4 XLE - '12 HiHi SE - '09 RAV4 - '06 HiHi
RIP Seattle Mike / Joe S. / Vinny D. / RTC
MikeyD25 is offline
post #10 of 28 Old 08-21-2013, 04:01 PM
Dergara's Avatar
Quoted: 3 Post(s)
Installed 2009 High and Low Camry Horns after purchase of my new 2012 HL. Love them and they are very loud. Think I paid $35 for the plug and play used horns.
2012 HL Base V6 4X4 Classic Silver Metallic. W/ Tech, Cold, and Towing package. Camry Horns Low/High, Michelin LTX M/S 245/65/17 including spare, Factory Trailer Hitch and Harness, Toyota Color Keyed Fender Flares, Door Molding (install in spring)
Dergara is offline
post #11 of 28 Old 08-22-2013, 02:29 AM
Senior TN Member
El Loco VG's Avatar
Quoted: 5 Post(s)
I will be swapping horns with the wife's 2012 Camry :-)
post #12 of 28 Old 08-22-2013, 08:04 AM
Quoted: 7 Post(s)
The first time I hit the horn on our '13 HL, I nearly croaked from embarrassment. Sounds like a clown car. Cannot blame you at all for swapping it out.
andrewst01 is offline
post #13 of 28 Old 08-22-2013, 03:55 PM
Resident Nutcase
sweeneyp's Avatar
Quoted: 1116 Post(s)
^ yep. The horns were the first mod on my HL...stupid "beep beep"
Click Here for the Full List of Mods Done to My Highlander ---->>> 2008 FWD Highlander Limited
sweeneyp is offline
post #14 of 28 Old 08-22-2013, 08:44 PM
Got Pyro?
funman1's Avatar
Quoted: 391 Post(s)
Where did you get them?
Part nums?
Professional Pyro..
No really; I get paid to blow stuff up...
funman1 is offline
post #15 of 28 Old 08-22-2013, 10:27 PM
MikeyD25's Avatar
Quoted: 46 Post(s)
Part numbers for the 2011 Camry horns that I used are: HORN ASSY, LOW PITCH #86520-AA010 and HORN ASSY, HIGH PITCH #86510-AA010.
Put these in my '12 SE a few months after getting her. Toyota of Dallas is where I ordered them from.
Sent from AutoGuide.com App
MikeyD25 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 2nd Generation (2008-2013)
User Tag List
Linear Mode Linear Mode
Back
