disable seatbelt chime - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2007, 05:03 PM   #1 (permalink)
View pauldivo's Photo Gallery
Does anyone know how to disable the seatbelt chimes on the 2008 highlander. Previous posts about this do not work on this model.
pauldivo is offline   Reply With Quote
Old 10-03-2007, 10:14 AM   #2 (permalink)
nim
View nim's Photo Gallery
there are some posts in the gen 5-5.5 camry area that you can search for that might help. hopefully the procedure will be the same.
nim is offline   Reply With Quote
Old 10-03-2007, 04:55 PM   #3 (permalink)
View toyotechwv's Photo Gallery
Your dealer can do that for you.
Shop Foreman L&S Toyota of Beckley
2008 Prius Package #2
1971 M35A2.....Tha Deuce
toyotechwv is offline   Reply With Quote
Old 10-04-2007, 04:09 AM   #4 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
This works on many other Toyotas. Not sure about the Highlander.
1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
2) Make sure seat belt is not fastened
3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
Passenger side instuction are similar, but slightly different(this requires two people to initialize, according to step 4.)
1. Turn the ignition switch on (without starting car)
2. Press the ODO/TRIP switch until the odometer displays "ODO"
3. Turn the ignition switch off
4. Turn the ignition switch on while depressing the break pedal
5. Sit in the front passenger seat. Press ODO/TRIP switch immediately (within 6 seconds after turning the power switch ON) and hold it down for 10 seconds or more.
6. Continue holding the ODO/TRIP switch and fasten the front passenger's seat belt.
7. Check that the odometer displays either "b-on" or "b-off" (it will be "b-on")
8. Press the ODO/TRIP button to change the display to "b-off".
9. Turn the ignition switch off.
10. Turn the ignition switch on while depressing the brake pedal.
11. Check that no buzzer sounds when setting on the front passenger seat.
Pb is offline   Reply With Quote
Old 10-16-2007, 02:36 PM   #5 (permalink)
View Fishballs15's Photo Gallery
Has anyone tried the above? Does it work?
Fishballs15 is offline   Reply With Quote
Old 10-16-2007, 03:12 PM   #6 (permalink)
Gameroom cash: $287705
View lucky777's Photo Gallery
Tried. Didn't work for me.
lucky777 is offline   Reply With Quote
Old 10-16-2007, 03:29 PM   #7 (permalink)
Bummer, looks like back to the drawing board.
Old 10-16-2007, 10:12 PM   #8 (permalink)
summerwind's Avatar
Gameroom cash: $393330
View summerwind's Photo Gallery
It requires the service department to plug in their "intelligent tester" to change the setting (as well as others).
Most dealers will not deactivate this setting. Some dealers have agreed to turn of the passenger buzzer.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Disable the key-in-ignition chime on a 1st gen? zirconx 1st Generation (1995-1999) 2 03-31-2007 03:48 PM
Disable 2006 Camry Seat Belt Chime seanr56 5th & 6th Generation (2002-2006 & 2007-2011) 27 07-28-2006 12:01 AM
Gen 3.5 Key Chime Disable camryelaine 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-26-2006 03:22 PM
05 Avalon - Procedure to Disable Seat Belt Chime preskev 3rd Generation (2005-2012) 31 07-27-2005 10:18 PM
