Adding illumination to the window switches - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2007, 10:27 AM   #1 (permalink)
Gameroom cash: $287705
View lucky777's Photo Gallery
Did anyone think about adding illumination to the window switches? This should be very easy mod to do. Switch is very easy to remove and take apart. Button is hollow, 12V comes on green and blue wires. I'm thinking about lighting options. Round green LED in the button would look cheap. What other options available?
lucky777 is offline   Reply With Quote
Old 11-06-2007, 08:06 AM   #2 (permalink)
View travheat's Photo Gallery
I have a Scion xB and did something like you are talking about. I went junk yarding and found 3 auto window switches and replaced the non auto switches on the driver side. They are illuminated and work very well. It is easy like you said and didn't cost very much. Good luck
travheat is offline   Reply With Quote
Old 11-15-2007, 12:14 AM   #3 (permalink)
THL
View THL's Photo Gallery
Here is a solution for those that are not tech savvy
I kid you not, glow in the dark, hehe
Here is a site that offers many solutions: ClickHere
THL is offline   Reply With Quote
Old 11-24-2008, 09:38 PM   #4 (permalink)
View Brewster Smith's Photo Gallery
Does this make the windows auto?
silly question but if you replace the window switches with auto switches from the junk yard do those windows become auto up/down?
Brewster Smith is offline   Reply With Quote
Old 02-15-2009, 11:27 PM   #5 (permalink)
View jscurtiss's Photo Gallery
Gonna bump this up:
Has anyone gone through and actually done this mod?
A luminated lock/unlock would be helpful, too
jscurtiss is offline   Reply With Quote
Old 03-19-2010, 11:06 PM   #6 (permalink)
View nov0798's Photo Gallery
Anyone have any more info on this?
nov0798 is offline   Reply With Quote
Old 03-20-2010, 10:56 PM   #7 (permalink)
Caterpillar 60's Avatar
View Caterpillar 60's Photo Gallery
Haven't looked at the HL switches (other electrical mods ahead of it), but on another vehicle used flat topped low lumen LEDs glued flush into a hole drilled into the switch top. Use an appropriate voltage divider/regulator/resistor combo to drive the LEDs at the needed levels. A flat topped surface mount LED would fit a very small space.
The other option would be to place the LEDs in the well of the switch housings facing the button.
Personally, I think the buttons and the panel are kind of cheap looking for the vehicle.
Caterpillar 60 is offline   Reply With Quote
Old 03-22-2010, 06:40 PM   #8 (permalink)
Does anyone know if any of the Highlanders have illuminated window switches?
Old 03-23-2010, 03:14 PM   #9 (permalink)
View nick1sp's Photo Gallery
http://www.tundrasolutions.com/forum...ntrol-console/
not exactly what you want, but it's a start
nick1sp is offline   Reply With Quote
Old 03-23-2010, 05:22 PM   #10 (permalink)
I was actually thinking of adding an led to the door handle area, shining down on to the switches.
Old 03-23-2010, 11:18 PM   #11 (permalink)
OK, took the switch apart tonight, there is no way to add lights to it internally, time to find another way.
Power window switches on drivers door stopped working on 96 Camry. TommyN 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-12-2008 12:26 PM
Window switches not lighted. Dam!! sundarpn 5th & 6th Generation (2002-2006 & 2007-2011) 10 10-13-2006 05:38 PM
One Touch Window Switches onsknht 5th & 6th Generation (2002-2006 & 2007-2011) 30 09-29-2006 04:49 PM
Door card foam shifting out from under window switches, tweeter cover falling off too jbrams 3rd & 4th Generation (1992–1996 & 1997–2001) 1 08-08-2006 06:16 PM
Custom power window switches MikeX 2nd Generation (2005+) 0 06-26-2005 02:53 PM
