2008 Stereo Removal? - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2007, 07:30 AM   #31 (permalink)
View PMaggan's Photo Gallery
Originally Posted by dmdatwork View Post
Are the different modes something you have to configure prior to putting everything back together? Or is that something you can do via the radio or ipod controls?
No, the PIE unit does not have any switches on it. Once it is installed, you would never need to touch it again. On our vehicle, you change modes by pressing Preset 3 memory button on the nav. screen when you are using the Ipod. Preset 3 allows you to toggle between the two modes.
PMaggan is offline   Reply With Quote
Old 12-01-2007, 07:32 AM   #32 (permalink)
PLamarine's Avatar
View PLamarine's Photo Gallery
You just hit the "3" preset button on the radio to toggle back and forth between modes. Really easy.
Peter
2008 Silver Metallic Highlander Sport 4WD; TRD Air Filter, Body Side Moldings, 100% synthetic 5W-30 Amsoil, TRD Shift Knob, PIE Ipod Adapter, running boards, factory tow hitch, Parrot CK3100 Bluetooth Hands Free Kit, Inalfa ASI 840 Sunroof.
PLamarine is offline   Reply With Quote
Old 12-16-2007, 04:28 PM   #33 (permalink)
View dmdatwork's Photo Gallery
sorry to bring up an old thread, but i was wondering if anyone's tried to do both the iPod interface and a satellite radio install? If I understand correctly, with the PIE unit you can retain the satellite function. From some of the research i've done, most Satellite kits come with a receiver, antenna and some kind of an interface that allows text to appear on the factory deck; with the PIE already doing this for the iPod, will you need an additional interface for satellite or can the PIE unit also do text for a satellite radio? And if both are installed, how do you change through the modes? Any help would be greatly appreciated. Thanks in advance.
dmdatwork is offline   Reply With Quote
Old 12-17-2007, 02:48 PM   #34 (permalink)
View xsnrg's Photo Gallery
Originally Posted by PLamarine View Post
Yes, I did it. I like it alot. To browse through artist, album, etc. you turn the tune dial or the file up down button, then hit the scan button as the "enter" or like the middle button on the Ipod. Get it, you will love it. Get it from Andy over at anco auto, link here:
http://www.ancoauto.com/oscommerce/p...roducts_id=159
Make sure you get the harness also..he has the best price I found, and fast shipping.
I ordered one of these (got it from Andy at Anco). I have an ’06 Avalon Limited with JBL 6disc in-dash + Factory Nav. I know I’m not in the Avalon forum here, but I ended up in this thread b/c it was about iPod interfaces, and particularly the PIE.
My 8G Nano (3rd Gen) arrived Friday (12/14), so I installed the PIE that evening. It works...sort of...but not as described. Many 'bugs' and not much as far as an owners manual or trouble shooting, so I’m not sure where to start. I plan to call PIE tech support, but wanted to get some feedback from some of you that has this unit also.
When it plays, the sound is great, and it seems to work pretty well in manual mode with control from the iPod wheel. I'll attempt to list the issues I've seen and maybe someone can tell me if there is a fix for any of this.
1. The TEXT button function doesn't work. It pulls up the text box for a flash, but it is empty of data, and quickly disappears. Doc says it should toggle between artist, album, song title when pressed.
2. When I shut the car off and then come back, it does not resume play. The only way it will resume play is if I press the Preset 3 button to put it into Manual mode and then it starts playing where it left off.
3. The 'mode' box that shows SAT1 and then channel information stays on the screen constantly when in Advanced mode and it flashes back and forth between a few characters of the artists' name and then the song title and then the last half of the song title... constantly switching from one to the other and stays up all the time, erasing a 1” by 5” block of my Nav screen.
4. Sometimes FF and REW won't stop ... you have to switch the to Manual mode to stop it.
5. When you switch to manual mode, the box with the SAT1 channel info still shows the info (partial artist name and song title as mentioned above) for the last song you were playing.
6. the Up/Down arrows don’t work, on the stereo or on the steering wheel to go to Prev/Next track. Sometimes I can use Preset 1 and Preset 2 to do this, but other times those don’t respond at all.
There are other things & inconsistent behavior as well, but these were the ones I can remember now and the majors.
Any ideas? Could it not be fully compatible with the New Nanos? Could there be a firmware update for the PIE box itself that resolves these?
xsnrg is offline   Reply With Quote
Old 12-22-2007, 04:21 PM   #35 (permalink)
Bandito's Avatar
View Bandito's Photo Gallery
I've also seen most of these same issues with my installation of the PIE unit on my '08 HiHy with the JBL 6-Disc changer unit. PIE tech support wasn't much help other than to say that the interface hasn't been tested yet with this particular head unit. They did suggest that I return it and replace it with another one just in case it was a defective unit.
I have decided to return it and change to the new PA-20 Toy USA Spec iPod interface instead. It has all of the same features and I've had two of their interfaces in other vehicles and they worked well for me. I'm just waiting for it to ship as they're brand new and just slowly trickling out right now.
At least you know that you're not alone in your experience!
Saving the planet one trip at a time...
~ 2008 Highlander Hybrid Limited - Everything but NAV & RES
Bandito is offline   Reply With Quote
Old 09-17-2009, 12:52 PM   #36 (permalink)
View xgb788's Photo Gallery
i am looking at instaling a zune adapter
xgb788 is offline   Reply With Quote
Old 09-17-2009, 12:52 PM   #37 (permalink)
Originally Posted by PMaggan View Post
See the pic below for more details:
I drilled a hole in the front right side of the storage console and then routed the wire to the PIE unit which resides just under the Navigation/radio unit. I didn't have a drill bit large enough to fit the cable, so I had to cut it out as best I could. I plan on making a hole in the "carpet liner" that comes in the console so that you don't see this messy cutout when open. I tie-wrapped all of the excess cable right below the cupholder.
can you send me the pic? i cannot see it
2005 Toyota Rav4 Factory Stereo Removal shahbinoyk RAV4 Forum 6 09-08-2008 05:49 PM
Factory Stereo Removal help! 2006 Solara cneidle Solara 2 12-20-2007 11:45 PM
Stereo removal / instllation cneidle 5th & 6th Generation (2002-2006 & 2007-2011) 2 06-27-2007 02:33 PM
06 stereo removal hoogland98 RAV4 Forum 5 03-21-2006 11:05 AM
05 Highlander Stereo Removal john05Highland 1st Generation (2001–2007) 1 10-07-2005 08:22 AM
