Limited w/ Nav : How can I adjust the clock? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2007, 09:27 PM   #1 (permalink)
View kkielinski's Photo Gallery
First post - love the Highlander so far.
Just got an '08 Limited with Navigation yesterday and I can't, for the life of me, figure out how to change the time on the clock. The Navigation Manual says to see the Vehicle Manual and the Vehicle Manual only gives you directions to adjust it on a vehicle without Navigation. The DISP button doesn't function the same with Nav as explained in the manual. I sat in front of the thing for a half hour searching through every menu and can't find squat.
Please, I beg - someone help. My wife won't stop talking about the clock being wrong.
kkielinski is offline   Reply With Quote
Old 11-12-2007, 12:19 AM   #2 (permalink)
View DenverBrian's Photo Gallery
The clock display is on the smaller screen above the larger NAV screen - so you change it using the DISP button on the steering wheel. I just changed mine for standard time in my HL Sport with NAV.
2008 HL Sport 4WD - leather - NAV - XM - Cypress Green
DenverBrian is offline   Reply With Quote
Old 07-19-2009, 09:30 PM   #3 (permalink)
View SeaMuskrat's Photo Gallery
When I got mine, I was in the dealer lot for nearly an hour with the salesperson trying to figure this out.
Hit Disp on the steering wheel, not the dash.
NOT intuitive at all.
2009 Highlander 4WD Limited, Salsa Red Pearl, Navigation (hate it) Ash interior. Prestige Solutions Nav Hack and Toyota iPod Adaptor and RSES installed.
SeaMuskrat is offline   Reply With Quote
Old 07-19-2009, 11:34 PM   #4 (permalink)
Tinkerer
VorlonBlue's Avatar
View VorlonBlue's Photo Gallery
I hear you, like the other comments above, it's a bit awkward. Most important, this only involves the small display not the main NAV screen and the DISP button on the steering wheel.
Step 1. Locate the DISP button on the steering wheel.
Step 2. (Make sure your small display is on the screen showing just the time) (To change the small display clicking the DISP button on the steering wheel with toggle the small display to different screens) Hold the DISP button in for about 4 seconds until the small display shows a new menu. The first option is for the Clock. Hold the DISP button down for another few seconds until the clock menu pops up. It will show the hour and minutes. The hours should be blinking. To change the hours (They only advance up) Tap the steering DISP button until you get the desired hour. Wait 5 seconds and it will advance to the minutes. Again tap the DISP button until you get it to the desired minutes. Once correct just leave it alone for about 5 seconds and you're all set.
2008 HL LTD (Mag. Gray w/Tow) - K&N Filter, Air Box Charcoal Filter Removed, Nav Override , Silverstar HLs and Fogs, White LED Footwell Lighting, White LED Int. Lighting, White LED Puddle Lights, AMSOIL Synthetic Oil w/TRD Oil Filter. JDM Lexus Horn, Visor Decals Removed, White LED Visor Lights
VorlonBlue is offline   Reply With Quote
Old 02-28-2011, 01:46 AM   #5 (permalink)
View banessi's Photo Gallery
What about the date?
Possible a separate issue but I want to adjust the date. When I go to the calendar it shows (always) December 30th, 2000 as the date. All option are greyed out. Any ideas?
banessi is offline   Reply With Quote
Changing the amber clock display color - DIY OtherHand 2nd Generation (2005+) 13 01-31-2008 10:43 AM
All-New 2008 Toyota Highlander And Highlander Hybrid Raises The Bar humanoid Toyota News 12 10-15-2007 03:16 PM
clock display on the nav system jhobo4 Camry Hybrid 4 06-20-2007 05:25 PM
Sirius into 06 Sequoia limited w/ DVD & Nav, rear seat DVD outback sequoia Sequoia Forum 2 04-10-2007 05:27 PM
Inferior Nav System on 2006 Highlander melvinsb 1st Generation (2001–2007) 1 04-28-2006 01:18 AM
