SmartKey Trivia part Deux - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2007, 11:20 AM   #1 (permalink)
summerwind's Avatar
Gameroom cash: $393230
View summerwind's Photo Gallery
You can use the key fob to change how the SmartKey system opens the doors.
There are two settings.
Setting 1: the default is open the drivers door only if you touch the drivers side front door handle and open all doors if you touch the passenger side front door handle
Setting 2: Open all doors when either front door handle is touched.
Page 37 of the 08 HL Owner’s Manual
Switching the door unlock function (open all doors or just the drivers door)
It is possible to set which doors the (Smartkey) entry function unlocks
Step 1: Turn the “Engine Start/Stop” switch “OFF”
Step 2: When the indicator on the key surface is turned off, push and hold the “Unlock” button and the “Lock” button together for approximately 5 seconds. You will hear confirmation beeps when the setting is changed.
The SmartKey settings toggle each time this operation is performed.
Soooo... you can do this and try it and if you don't like it you can change it back.
Also the buttons on the key fob are a separate system from the Smartkey system.
Pressing the unlock button once only opens the drivers door and you have to press it twice to open all doors.
Changing the button settings requires the dealer to plug in the "intelligent tester" and change the customizable settings that are available (like how long the headlight off delay is set for..default is 30 seconds but you can have it changed to 0, 60, 90 seconds)
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is online now   Reply With Quote
Old 11-15-2007, 10:08 PM   #2 (permalink)
becks's Avatar
Gameroom cash: $100120
View becks's Photo Gallery
Summerwind thanks :-)
08 4WD HL Limited, Magnetic Flint/Ash Leather, Toyo OC HT's 255/55/19's, European Horns, Extended Step Plate On Rear, DeBadged All Around. No NAV/DVD
__________________________________________________ ___________________________________
becks is offline   Reply With Quote
Old 11-16-2007, 07:30 PM   #3 (permalink)
Kluger Driver
View takahashi's Photo Gallery
Australia
My first post here from down under , and been reading the manual it is very confusing.
for explaining it to us in plain English.
takahashi is offline   Reply With Quote
Old 11-16-2007, 08:23 PM   #4 (permalink)
summerwind's Avatar
The manual could be better.
The Bluetooth section has you reaching for a Fosters...
So how big are the letters on the back that say "Kluger"
I understand it means "clever in German
Old 11-17-2007, 07:05 AM   #5 (permalink)
Kluger Driver
Summerwind,
the Bluetooth section I mastered but wanting to know if there is name display if the contact is stored in the car.
The "kluger" word is exactly the same size as highlander, so it is less congested on the plate.
looking for a part # MrGrimm 2nd Generation (2005+) 7 04-11-2007 01:13 AM
intake part ? speedyts49 Celica Forum 2 08-19-2005 11:07 PM
FS: 92-96 Cheap lexus part out or whole car. ES300. winner007 Vehicles 0 08-16-2005 03:30 AM
Factory part number for '06 stock stereo? Celica4life Scion Forum 5 08-11-2005 02:36 AM
Fast and the Furious Part Deux =) TRDCelica Off Topic 0 03-08-2002 05:09 PM
