Removing rear fascia? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2010, 02:49 AM   #1 (permalink)
View dirsynced's Photo Gallery
I'm trying to remove our HL's rear fascia thats on a 2010 SE to get it painted to match the color of the vehicle, but as I was in the middle of getting it removed I noticted that there are two locking plastic snap clips on each side. The only way I see to remove these is by cutting them off is there an alternative method of getting them off so I can get the rear fascia painted where the tow hook is supposed to be?
thanks all!
dirsynced is offline   Reply With Quote
Old 03-17-2010, 06:40 AM   #2 (permalink)
summerwind's Avatar
Gameroom cash: $451030
View summerwind's Photo Gallery
You can use needle nose pliers to work the clip out if you are removing the fascia from the rear bumper. The attached page shows the clip but if you do cut the tabs as described in step b you can't reinstall the fascia correctly.
Just compress the clip and work it out.
Rear Fascia
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 03-17-2010, 07:35 PM   #3 (permalink)
Rear Fascia
Great thanks for the information! I called around today and found a
reputable shop that would take it off for me and prep/paint it for $100 bucks. Three coats of paint and a clear.
B4
After:
Old 03-17-2010, 07:57 PM   #4 (permalink)
View bobert1634's Photo Gallery
Looks good. I used to have a Van that was painted silver and then a clear-coat over it. I had to take it in for a touch-up job and was WARNED ahead of time that silver was very difficult to match up. I had to sign off on the possibility that there might be a slight difference in shade. Yours looks nice.
'09 Salsa Red Sport
bobert1634 is offline   Reply With Quote
Old 03-17-2010, 09:10 PM   #5 (permalink)
summerwind's Avatar
Nice clean look. I de-badged my lift gate as well (just left the 4WD on though)
Sounds like they did the job right.
I had the tow hitch fascia painted to match on 08 (see sig pic) and have not had any problems with chipping or cracking.
Old 03-18-2010, 08:11 PM   #6 (permalink)
Dman1's Avatar
Gameroom cash: $135752
View Dman1's Photo Gallery
I hear you on the color matching. I had a 2005 Camry and I still have my 2005 Corolla, both silver. Both are Toyota's built in the same year, and both were slightly different in color. You would never know it otherwise, even when they were beside each other in the garage, it was hard to tell. You needed to have decent lighting to see it. Their color names were different, but it was still surprising that they were not the same color.
2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
Dman1 is offline   Reply With Quote
Old 03-19-2010, 06:24 AM   #7 (permalink)
View dixon422's Photo Gallery
Looks nice. Hopefully (probably), they added a flex agent to the primer and base coats so it won't crack over time.
Yes, metallic colors are tougher to match. Getting the same concentration of metal "shimmer" in each mix is almost just by luck, even for the manufacturer doing a repair.
'08 Highlander Sport, Magnetic Grey 2WD, options - Wife's ride
'04 Solara SLE V6 coupe, Lunar Mist Metallic: Wife's old ride..now mine ... TRD springs, 18" wheels, TRD exhaust, Intake w/ MAF mod.
dixon422 is offline   Reply With Quote
Old 03-19-2010, 07:47 AM   #8 (permalink)
Thanks for the comments all.
You know I honestly didn't ask i'll have to give them a ring tomorrow and find out. I know they sanded it down so everything is totally smoth and sprayed it I think the guy said three times.
They do also offer a lifetime warranty on the work as long as I own the car from any paint defects, so hopefully it will stand up.
Old 03-19-2010, 10:57 AM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
That area of the vehicle, though, picks up the most road grime and dirt so if the paint does not match it'll be mostly unnoticeable. Thank goodness it's not a driver's door or something.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
