Back door will open with smart key but not close - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2010, 08:46 PM   #1 (permalink)
View toyaconn's Photo Gallery
Although the back door will open when any button is activated, when I try to close the back door using either the button on the dash, the button on the back door itself, or the smart key, I hear two quick beeps but the door does not close. Can anyone help?
toyaconn is offline   Reply With Quote
Old 04-01-2010, 06:54 AM   #2 (permalink)
View ebstauffer's Photo Gallery
There's a switch in the glovebox that controls the ability to open/close the rear hatch. Make sure it wasnt toggled by accident.
ebstauffer is offline   Reply With Quote
Old 04-01-2010, 07:03 AM   #3 (permalink)
Thanks, I did check the button and it is set "on."
Old 04-01-2010, 09:27 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
Don't know if reply #8 from this thread will help you out with your issue, but from memory it's the only thread I recall with an issue that resembles yours.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 04-01-2010, 10:14 PM   #5 (permalink)
Thanks, I did see that response and tried the second smart key. It didn't work. I drove over to the dealer who tried to reset the key; check the button in the glove compartment; check the fuse; and disconnect and reconnect the battery. Nothing worked. As a result, the key will no longer even open the door. I've been told to make an appointment - it's an electrical problem. I appreciate your taking time to suggest a solution.
Old 04-02-2010, 12:41 PM   #6 (permalink)
View jeffs3820's Photo Gallery
Make sure the button in the glove box is pressed IN
2008 Highlander Hybrid Limited; Nav, DVD (His)
2007 Volvo XC70 (Hers)
1999 Camry LE (mine, used by my son)
jeffs3820 is offline   Reply With Quote
Old 04-02-2010, 12:58 PM   #7 (permalink)
The button is in the on position - thanks.
