Originally Posted by HighlanderJohn2010
I am considering doing this for my 2010 Highlander Hybrid. If I understand your situation you currently have the new unit installed and everything works except for the steering wheel controls and the microphone. Am I understanding correctly?
It also sounds like you are looking for the pinout for each of the versions of the stereos so that you can figure out how to crack open the connector and make your own connections. Right?
Did you get any documentation with your new stereo?
If you take the existing connector that connects to the current steering wheel controls, can you use a multimeter to figure out what wires are for the volume, what ones are for the mode, what ones are for the channel change? Am I makeing any sense with these questions?
The issue was finding the right plug for the back of the nav unit. After a lot of frustration and forum reading I did find the plug and was able to order it from Toyota (part# 90980-12404, 24 pin connector). With this I was able to get the mic working which also made the steering wheel controls work for speech. Because at the time I did not have any wiring diagrams I could not get the back up camera to work thru the nav unit screen.
I have since found an excellent site that provides diagrams for any make and year and was able to get the diagrams that also identify the pin locations and the wiring colors and IDs for $9.90......well worth it. That site by the way is
http://www.freeautomechanic.com/wiringproblems%202.html you will need it if you do want to do it yourself.
Now that I have the diagrams I will rewire the plugs to the nav unit wiring and everything should work as OEM. Will update when completed.
