Hi Everyone
Just got my 2010 HL v6 4x4 base model with Extra Value Package #2. Now I have a long todo list. First is Carpet Mats, very simple, go to trdparts4u.com order the PT919-48080-22. I compared it with other sites and believe they have the best price. (weathertech is another option but I read complaints said that it's not safe, gas pedal will get stuck on the edge...)
Second is the fog light, This will be my first real project. I found this on ebay
Hi Everyone
i just installed these about two months ago and they work great, only problem is that they come with next to no install instructions but if you have a basic knowledge of wiring then you can do it. i also bought one to many sets so if still need a set then i can sell you my other set a little cheaper then ebay. and for the air intake problem i just removed the leds on both sides, they come out with four scres each.
Thanks everyone.
I will order thoese fog lights and install them next week. For air intake issue, I hope it's ok as I don't tow at all and I do notice there are other holes under it.
Hi Everyone
Just got my new fog light set. Does anyone know where I should connect the 2 pin power wire of the side LED? I am planning to use the pre-wired harness instead of the one come with the light set.
Thanks
Just installed the fog lights during the past weekend. Not a easy job as I installed them from the top by using hands and without looking at anything down there. (I was too lazy to take off anything). Then I took off the steering wheel column and connected PIN 3 and 4 together. Unfortunately, when I start my 2010 US build highlaner, nothing happened.
The fog light relay is not there. (Instrument panel fuse box or engine fuse box? they are both empty)
I need a 4 pin toyota relay now.
BTW, KDHL, Thank you for your help.
Mine is 2008 Japan made Highlander. I just installed the lights and connected the two wires. The fog lights work fine. But I don't know whether that's with or without relay.
Finally, It's done. Looks awesome.
I bought a new relay from a local store for 40 bucks. Not cheap. May be I should get a used one from ebay, but this project has been taken for too long. So I just get it and insert it into instrument panel relay box. Again, not a easy area to reach as I didn’t take off panel trim.
