Please help with power tailgate issue, dealer is clueless. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2010, 03:14 PM   #1 (permalink)
View cdnlimited's Photo Gallery
Hello everyone. I've been trolling this site for ages but finally have joined this awesome community.
I wish my first post was more pleasant in nature but alas I have no choice. :-(
Anyway, our 2008 Highlander Limited's power tailgate has stopped closing on it's own. It opens up without issues on its own but when you press the close button there is a long beep and then nothing happens. We have to manually close it shut. I took it to the dealer today and they are totally stumped. They want to replace the $2000.00 power tailgate motor but they cannot guarantee that it will be fixed. Needless to say, we will never spend the 2k to fix it because its just not worth it but is the dealer missing something? Why would the power motor be broken when it has no problem oping the tailgate but only has issues closing it?
Thanks in advance for your help.
cdnlimited is offline   Reply With Quote
Old 06-18-2010, 03:45 PM   #2 (permalink)
I'd Rather Be Riding...
RedLdr1's Avatar
View RedLdr1's Photo Gallery
Have you tried closing it with the switch on the dash to see if you get the same result as the rear hatch switch? It might be a bad switch on the hatch....
Wayne
2008 2WD Limited Blizzard Pearl, Towing Package / Hitch
Mods: Formula 1 Ceramic Window Tint, SportWing Bodyside Moulding, SmittyBuilt Hitch Step, SilverStar Ultras, AVS Bug Shield, Wong's Neoprene Inserts, MGT V-1 Mirror Mount, JDM Horns, Toyo P245/55R19 Open Country H/T
RedLdr1 is offline   Reply With Quote
Old 06-18-2010, 04:03 PM   #3 (permalink)
Hi Wayne. Yes I've tried the dash switch, the keyless fob and the switch on the tailgate. They all produced the same result. It opens but when you go to close it there is a long beep and then nothing........
Old 06-18-2010, 07:21 PM   #4 (permalink)
View jeffs3820's Photo Gallery
Open the glovebox and check the switch setting (on far left side)...it should be in the "in" position.
I don't think it's that but it's worth a check. On my car when the glovebox switch is "out" and one presses the button on the remote to open the trunk the car just beeps twice regardless if the hatch is open or closed.
If it's not the button position, it has to be wiring or a relay. It's not the motor if the hatch opens. The motor just runs in reverse to close. This usually is a relay. You need a shop with decent electrical troubleshooting skills. Most dealers charge by the hour for electrical issues. First step is a wiring diagram so run from the dealer that wanted to change the motor for 2 grand...
2008 Highlander Hybrid Limited; Nav, DVD (His)
2007 Volvo XC70 (Hers)
1999 Camry LE (mine, used by my son)
jeffs3820 is offline   Reply With Quote
Old 06-19-2010, 03:39 AM   #5 (permalink)
View ganue's Photo Gallery
I would be checking if there is an open and a close relay, and swapping them over and seeing if the fault transfers over. Not sure how the car knows the door is shut, but i would be seeing if there is a door fully closed limit and checking it functions correctly.
ganue is offline   Reply With Quote
Old 06-19-2010, 08:22 PM   #6 (permalink)
RedLdr1's Avatar
I agree, it most likely isn't the motor... A relay or some type of reverse actuator is most probable... If you are out of warranty I would find a competent independent to look at it as the dealer sounds clueless and is just throwing a bunch of $$$ and parts at the problem...
Wayne
