The tires are Bridgestone Dueler H/L 400 - 245/55R19 (on the 19" Sport rims).
When I purchased it, the test drive showed a slight vibration at 50+mph, so I had them balance the tires, and the vibration is gone... then I purchased it. I don't think I noticed the humming noise before the tires were balanced.
I also noticed that when I swerve slightly at higher speeds (just testing on a clear highway), the humming noise changes or goes away mostly, which I can see coinciding with your tire suggestion.
Now to just figure out what that whistling noise is from the engine compartment @ 2300 RPM (seems like there is a sizable thread on this forum already about it).
Thanks for the reply!
