Ok, I came across this TSB for the 2007 Highlanders does this also apply to the 2008? I have the SAME exact symptoms... do i need to pay $300 to fix it or is it just an annoyance? I don't have the money right now:
Steering - Clunk/Pop/Knock When Turning Steering Wheel
STEERING
ST001-06
Title:
STEERING INTERMEDIATE
SHAFT NOISE
Models:
'03 - '06 Camry, '04 - '05 Highlander, & '04 - '06 Solara,
February 16, 2006
TSB REVISION NOTICE :
^July 20, 2006: 2004 - 2005 model year Highlander vehicles have been added to Applicable Vehicles. Production change effective VINs for the Highlander have been added to the Production Change Information table. The Parts Information has been updated to include the Highlander.
Previous versions of this TSB should be discarded.
Introduction
Some customers may hear a clunk, pop, or knock type noise when turning the
steering wheel left or right. A new intermediate shaft has been developed to address this concern.
Applicable Vehicles
^2003 - 2006 model year Camry vehicles produced BEFORE the Production Change Effective VINs shown in this TSB.
^2004 - 2005 model year Highlander vehicles produced BEFORE the Production Change Effective VINs shown in this TSB.
^2004 - 2006 model year Solara vehicles produced BEFORE the Production Change Effective VINs shown in this TSB.
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
*Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Parts Information
Repair Procedure
Prior to removing the
steering intermediate shaft, make sure the
steering wheel and front
wheels remain stationary. Once the intermediate shaft is removed, do NOT allow the steering wheel to spin freely.
NOTE :Ensure the
wheels are straight and the
steering wheel is centered before removing the
steering intermediate shaft sub-assembly by installing a steering wheel holder.
1.Disconnect the
steering intermediate shaft sub-assembly.
A.Loosen the bolt and remove the clamp from the
steering column hole cover boot.
B.Separate the
steering column hole cover from the steering column hole cover boot.
C.Place matchmarks on the
steering intermediate shaft sub-assembly and
steering gear assembly.
D.Remove the bolt and disconnect the
2.Remove the
A.Place matchmarks on the
steering sliding yoke sub-assembly and steering main shaft assembly.
B.Remove the bolt and
steering sliding yoke sub-assembly from the steering main shaft assembly.
3.Place the corresponding matchmarks on the NEW
To place the matchmarks on the NEW
steering intermediate shaft sub-assembly, place a NEW steering intermediate shaft next to the original steering intermediate shaft assembly (removed in the previous step) and transfer those match marks to the same locations on the NEW steering intermediate shaft.
4.Install the NEW
A.Align the matchmark with the one on the
steering sliding yoke sub-assembly and the steering main shaft assembly.
B.Install the
steering sliding yoke sub-assembly with the bolt.
Torque: 35.3 N.m (360 kgf.cm, 26 ft.lbf)
5.Connect the
A.Align the matchmarks on the
steering intermediate shaft sub-assembly and the
B.Install the
steering intermediate shaft sub-assembly with the bolt.
C.Install the
steering column hole cover to the
steering hole cover boot.
D.Connect the clamp to the
steering column hole cover boot and tighten the bolt.
6.Remove the
steering wheel holder from the vehicle (if used).
7.Road test the vehicle to verify the repair and confirm that the
steering wheel is centered. __________________
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
