I understand. The Toyota parts guy I called out of state indicated the distance on the factory ball to pin was 4 3/4". Quite a difference from the standard 8 1/2". I was just looking for confirmation of 4 3/4" as that seems kinda short. I don't want toyota pointing to something like that to void a warranty issue some how related to towing.
WHOA! 4 3/4 inches? I wouldn't trust that length. Even with my 8 1/2 inch ball mount on mine it still looks like my boat is gonna come through my back window.
Just getcha a standard Reese or similar ball mount and call it a day.
This is the same hitch I use with my toyo OEM hitch bar...except it is reversed..with the drop going down. I have been towing a combined weight of 4,000lbs with it for 2 summers now.
Originally Posted by areamike
08 4WD HL Limited, Magnetic Flint/Ash Leather, Toyo OC HT's 255/55/19's, European Horns, Extended Step Plate On Rear, DeBadged All Around. No NAV/DVD, OEM Hitch with Color Matched Fascia.Höen Endurance Amber Fog Light Bulbs.
__________________________________________________ ___________________________________
Speaking of towing weight. I tow a boat that has a dry weight of about 2600lbs. I'm not sure what the tongue weight would be on that, but I do notice that when I have the boat hooked up to my HL, there is quite a bit drop in the back end of the vehicle. Don't these HL's have some kind of leveling shocks or something. I know in our old mini van if I loaded up a bunch of cargo in the back area, some pneumatic air would kick in and raise the rear end of the vehicle until it was back to level again.
I agree, the rear springs are too soft for towing. My snowmobile trailer has a tongue weight of about 200lbs, plus all your gear in the rear, makes it sag more than ideal. Not that it causes any significant problems other than your headlights are aimed too high if towing at night. I have the Sport which is supposed to have a stiffer suspension but I bet this is just a shock configuration vs. stiffer springs.
You can get air bags installed aftermarket like your old van had but I have no idea with this costs. Weight distribution hitches are an option but should this really be necessary for only 200lbs. Besides, there is debate whether or not one can be used for a unibody vehicle.
I’m considering a boat which will weigh 3,500lbs dry which I’m guessing will have a 350lb tongue weight and I’m concerned about sag.
I was going to recommend a weight distribution hitch. I have one to tow my approximately 4200lb loaded hybrid that likely has a tongue weight of around 500lbs and it is as level as it is with nothing hitched to it. In fact, the rear end sagged lower when I towed my 1800-2000lb hardtop (likely around 200lb tongue weight) without a WDH.
Ah yes, the old weight distribution hitch (WDH) debate. There are plenty of us on here that are using them. Most of us have come to the conclusion that it is simply a Toyota 'cover your ass' clause. I've seen lots of minivans use WDH for years with no issues. Towing an (up to) 5000lb trailer without a WDH with sway control, in my opinion, is like skydiving without a parachute. The tail will wag the dog, so to speak, whenever you drive past another high sided vehicle. The fact that Toyota have been marketing the HL as having a 5000lb towing capacity (properly equipped), but do not recommend using a WDH is pretty stupid in itself. One recommendation that I have read that makes sense is if your trailer weighs more than 50% of your towing vehicle (in my HL Limited's case, 4321lbs x 0.5 = 2160lbs.....maybe a little higher when you factor in cargo and people, but even based on the GVWR, based on this assumption, you shouldn't tow anything above 3000lbs without a WDH.
Anyways, that's my $0.02. If after a few years, my use of a WDH twists the frame of my HL or rips it apart, I will be on here to recommend against using a WDH with the HL, but at this point, I am not concerned.
__________________ 2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
well I don't know much about towing with the highlander since we use our 1999 Lexus LX470 for that, but I can say when the back of my 08 Highlander limited is fully loaded the back end sinks significantly. It sank so much I feared driving at night since my headlights were pointed up straight at oncoming traffic. The soft limited trim springs don't like 300-400lbs of weight over the back axle otherwise it dips. so a weight distribution hitch would make sense to try and get some of the dead weight off the rear axle.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
