Hood deflector install picture - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2010, 12:30 PM   #1 (permalink)
Gameroom cash: $145500
View nogo's Photo Gallery
Folks - I bought an OEM Hood Deflector from the dealer but didn't get any instructions with the product, just the saran-wrapped deflector and a parts bag. The part # is PU50048081 and this will be going on a '10 Highlander Sport.
Via Google, I found install instructions for an '08 Highlander hood protector (Part #PT427-48080) and have noticed some differences:
1. In the '08 instructions, there are 8 tabs on the deflector. For the '10, there are only 4 tabs.
2. In the '08 instructions, there are 8 brackets. In the '10 parts bag, there are only 2 brackets.
Does anyone have the inside pictures of an '09 or greater OEM hood protector install? I think the 4 inner tabs will hook up to existing holes in the hood (under the weather-stripping) and the two brackets are for the two outer locations on the protector?
Any feedback or pictures would be greatly appreciated. Thanks in advance!
[Update]
Removed four nylon inserts / fasteners from under the leading edge of the hood and replaced with 4 nylon inserts from the kit. The protector slides in between the hood and the weather stripping and is secured by 4 machine screws and washers.
Also installed the two metal brackets on the outer-most edges of the hood using two round nylon fasteners. The only issue is to affix the protector to these two brackets. The two remaining round nylon fasteners are two weak to hold the protector to the bracket. Will try and get some nuts / bolts from Home Depot to fasten them. Hope it doesn't look bad.
Last edited by nogo; 10-15-2010 at 04:10 PM. Reason: Additional install details added
nogo is online now   Reply With Quote
Old 10-30-2010, 11:54 AM   #2 (permalink)
View high09ltd's Photo Gallery
still require the instructions? I have a PDF
high09ltd is offline   Reply With Quote
Old 11-01-2010, 05:05 PM   #3 (permalink)
Thanks it was pretty straight-forward even though no instructions were included. My only issue was with the bolts to secure the deflector at the far ends to the supplied brackets.
Home Depot helped solve that
On to the pictures - excuse the quality:
Leading edge of the deflector goes under the weather-stripping:
Brackets for the edge:
Home Depot bolts, cut to size with a dremel:
1997 Jetta GLS, 2007 E280 4Matic, 2010 Highlander Sport
Old 01-06-2011, 08:51 PM   #4 (permalink)
View ewoltje's Photo Gallery
If you still have the pdf, can i have you send it my way? Thanks in advance.
ewoltje is offline   Reply With Quote
Old 01-07-2011, 03:15 PM   #5 (permalink)
pestictide1480
View pesticide1480's Photo Gallery
sure would like to find one for a 2011 highlander,2010 won't work close but no bannanas
pesticide1480 is offline   Reply With Quote
Old 01-09-2011, 04:05 PM   #6 (permalink)
I was actually able to find directions for a 2011 hood protector; only problem is I'm new to this forum and I can't seem to figure out how to upload the pdf. Let me know if there is a simple way to upload and I will post them. Thanks
Old 01-09-2011, 08:07 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
The easiest way is to use a free file hosting service, such as FileFactory or WebNG. Sign up, and once your files are hosted you can post pics to the forum by clicking on the share an URL icon above the reply window (5th button from the right), then paste your URL into the small window that has opened up. Click Okay, then a hot link to your pdf file will appear in your reply. If you have any questions while going through that process, don't hesitate to shoot me a private message.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 01-09-2011, 08:46 PM   #8 (permalink)
Here is a link for directions to mount a 2011 hood protector. Hope it works:
http://www.filefactory.com/f/d966ffb41334dc39/
2011 Highlander SE 4x4
Blizzard Pearl, Black Leather
Remote Start, Body Side Moldings
Mud Guards, Hood Protector
Last edited by TrailDust; 01-09-2011 at 09:57 PM. Reason: No editing done, just checking on link....
Old 01-25-2011, 09:58 AM   #9 (permalink)
View rcash's Photo Gallery
Wink
I have been looking for a bug/hood deflector for my 2011 Highlander with no sucess! Can you tell me where you found yours? Thanks.
rcash is offline   Reply With Quote
Old 01-25-2011, 10:48 AM   #10 (permalink)
I broke down and bought mine through the Toyota dealer. It ran about $120. Luckly, I had a 20% off coupon and had an additional gift card for $50. In the end it only cost me about $55. I tired weathertech, but they do not have them out yet. You may be able to find one at a truck accessorie shop for less. If you have to go through your dealer I would keep an eye out for any discounts on their website. Good Luck; hope you find one.
Old 01-25-2011, 11:22 AM   #11 (permalink)
Wink
Thanks for the info! I checked a while back with my dealer but the protector wasn't out at the time. I will give them another call! I have installed bug flectors on a couple of vehicles and the really do help to cut down on rock chips to the hood area.
Old 01-25-2011, 05:42 PM   #12 (permalink)
View caf2461's Photo Gallery
Nevermind found part # for hood deflector in the bug sheild post.
bug shield
caf2461 is offline   Reply With Quote
Old 01-25-2011, 08:25 PM   #13 (permalink)
View MikeyD25's Photo Gallery
Can anyone here post a pic of the 2011 HL with the HOOD DEFLECTOR attached?
Thanks!
MD
In memoriam NYPD DAOS / NYS OIG #77
'12 Highlander SE - Sizzling Crimson Mica / Black Interior / V6 / 4WD + Tow Prep Pkg; OEM Mud Guards; OEM All-Weather Mats; Camry horns; Weathertech Vent Visors & AVS Bugflector II.
'09 RAV4 Base
- gone.
'06 Highlander Base
- gone.
R.I.P Seattle Mike / Joe S.
MikeyD25 is offline   Reply With Quote
Old 02-17-2011, 04:13 PM   #14 (permalink)
View PaPaStewySnipes's Photo Gallery
toyota highlander hood reflector pt427-48110
http://www.trademotion.com/partlocat...catalogid=3479
PaPaStewySnipes is offline   Reply With Quote
Old 04-30-2011, 10:21 AM   #15 (permalink)
View wrightwrjr's Photo Gallery
Question
Do the hood protectors only come in one color?
wrightwrjr is offline   Reply With Quote
