Help me pick a tire - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Which one would you go with?
245/55-19 Toyo Open Country H/T (OEM size) 2 16.67%
255/55-19 Bridgestone Dueler H/L Alenza 6 50.00%
Neither (write-in suggestion) 4 33.33%
Voters: 12. You may not vote on this poll
Old 10-18-2010, 04:15 PM   #1 (permalink)
View Zeus69's Photo Gallery
Help me pick a tire
The stock Bridgestone's on my 2009 HL-Limited are down to about 5/32 mm and I don't want to enter the bad weather season here in the midwest with my current setup. I've looked around at replacements and have it down to two options...
Current setup made it 27,500 miles with regular 4-tire rotations. Would be curious what folks have to say.
Thanks.
Zeus69 is offline   Reply With Quote
Old 10-18-2010, 05:24 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
19 wheels are a pain to find tires, not much options. OEM tire never late long but 27k is pretty good at 5/32. I would go for the Toyo unless the slightly larger Bridgestone is cheaper.
Here's a forum on the Toyo Open Country H/T of the OEM size.
New Toyo Open Country H/T - 245/55/19
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 10-18-2010, 05:38 PM   #3 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
http://toyotires.com/tire/pattern/open-country-ht
http://www.bridgestonetire.com/tires...productID=1090
Both seem to be reasonable long lasting tires and should easily last twice as long as the stock tires.
Another option:
http://toyotires.com/tire/pattern/versado-cuv
I'd run either of these year round instead:
http://www.bridgestonetire.com/tires...productID=-169
http://www.nokiantires.com/tyre?id=1...me=Nokian+WRG2
deadrx7conv is offline   Reply With Quote
Old 10-19-2010, 07:46 AM   #4 (permalink)
luck123's Avatar
View luck123's Photo Gallery
I am getting the Toyo Versado CUV for my summer set of wheels as part of deal with Toyo to credit for premature wear of my A20s. I looked at the H/T but read that they are slightly noisier, and prefer to have a quiet tire. I don't need a more aggressive tread...I have a separate set of wheels/tires for winter and I generally do not go off road. The CUVs are getting good reviews on other forums. Something to consider.
Cheers.
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
Old 10-19-2010, 05:09 PM   #5 (permalink)
View wvcreditman's Photo Gallery
Tire Choice
Between the two I would go with the Bridgestone. I have a 2010 Highlander 4WD Limited that I purchased at the end of August. I noticed some type of vibration after I drove it for a few days. The dealer said the tires were bad and replaced them. It came with the Toyo's and the dealer put the Bridgestone H/L 400 on it and they are way better than the Toyo's.
2010 Black Highlander Limited 4WD V6
wvcreditman is offline   Reply With Quote
