Question on 2010 HL Climate Control - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2010, 02:14 PM   #1 (permalink)
View kkovak's Photo Gallery
When I have my 2010 HL climate control in AUTO the AC light is always lit, even if the system is trying to warm up the car.
So my question is when this is in AUTO and the AC light is on is the AC really running all the time or does it only kick in when the system is trying to cool down the interior?
Thanks
Ken
Ken K.
Lehigh Valley, PA
2010 Highlander SE AWD in Magnetic Grey
2003 Avalon XL in Silver Spruce Metallic
kkovak is offline   Reply With Quote
Old 10-27-2010, 03:25 PM   #2 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
AC isn't just for cooling. It will be used to control humidity and as a defogger(reduce moisture/humidity). So, if the light is on, its cycling. I never use Auto!
deadrx7conv is offline   Reply With Quote
Old 10-27-2010, 03:37 PM   #3 (permalink)
becks's Avatar
Gameroom cash: $126215
View becks's Photo Gallery
USA
Yes the AC is running. I use auto all the time. When I don't want the AC going I just tap the AC button to turn the AC off, and the system remains in Auto. Just no AC. As far as I am aware..the HL does not return lower MPG because the AC is running.
08 4WD HL Limited, Magnetic Flint/Ash Leather, Toyo OC HT's 255/55/19's, European Horns, Extended Step Plate On Rear, DeBadged All Around. No NAV/DVD, OEM Hitch with Color Matched Fascia.Höen Endurance Amber Fog Light Bulbs.
__________________________________________________ ___________________________________
becks is offline   Reply With Quote
Old 10-27-2010, 07:58 PM   #4 (permalink)
luck123's Avatar
View luck123's Photo Gallery
Originally Posted by becks View Post
yes the ac is running. I use auto all the time. When i don't want the ac going i just tap the ac button to turn the ac off, and the system remains in auto. Just no ac. As far as i am aware..the hl does not return lower mpg because the ac is running.
+1
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
