Second row removal? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2010, 08:46 AM   #1 (permalink)
Toyota Freak
Gameroom cash: $105200
View earthltd's Photo Gallery
Second row removal?
I will need to remove the second row seats to get my camping and telescope gear into my 2011 HL. Has anyone done this on their 2nd Gen?
Is it mainly removing the bolts holding the glide rails to the body and lifting the seat out in one piece? I hope the bolts are blind and I do not need to access nuts on the underside.
What are the cables running from the seats into the body? It looks like I would have to remove the seat before I can even see how they might disconnect.
With my previous vehicle ('93 4Runner), I had the factory manuals with all mechanical info. Is there any similar source for the HL?
earthltd is offline   Reply With Quote
Old 11-06-2010, 04:34 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
Google Toyota's TIS (Technical Information System), which is the complete manual online with downloadable documents, etc. $15 for a two day subscription last I checked. I used information from TIS that helped with the removal of my 3rd row seats and interior side paneling...very helpful.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 11-06-2010, 09:39 PM   #3 (permalink)
Toyota Freak
Thanks! Sounds like exactly what I need. I'll check it out next weekend.
Old 11-15-2010, 06:34 AM   #4 (permalink)
Toyota Freak
TIS tips
Before you sign up, you can easily spend more than an hour on the tutorial (very worth it), FAQs, and updating Adobe and Flash. I recommend the free CutePDF utility to print the PDF's to files. When you go to print, you can select CutePDF as a printer. It then prompts you for the Folder to store it. Easy.
Browsers;
Firefox let me save the PDF's under their own name automatically. Explorer saved to a single default name (ugh, too much typing to correct). On the other hand, Firefox did not display enough of a couple of buttons at the top to be able to use them. Hopefully these problems will be fixed.
The two day subscription was actually longer. I signed up on Saturday morning and it didn't expire until Monday, 11:59PM PDT.
Tons of documents. Have your areas of interest written down to search. Just browsing through is interesting and you can find gems but you wouldn't want to miss saving useful info when you run out of time.
The Following User Says Thank You to earthltd For This Useful Post:
TrailDust (11-15-2010)
Old 05-12-2011, 07:20 AM   #5 (permalink)
Toyota Freak
The second row seats came out. The only difficulty was disconnecting the previously mentioned cables running to the left rear of the car that fold the seats down when you are at the hatch.
To level the area for packing gear, I made a platform that drops in and easily bolts down. The holes around the edge are for tie downs. I found a $20 adjustable cargo net that should be perfect for keeping the gear from shifting while letting us access a cooler and personal gear on the road. All the gear should fit without exterior storage. (And I still have roof rails and tow hitch for future use.)
The 3rd row area doesn't have a best solution yet. Those seats are never going back in unless I sell the vehicle.
I can hardly wait for this summer's trips!
Old 05-12-2011, 11:02 AM   #6 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
You should have gotton a minivan, much easier when it comes to carrying things around.
Last edited by TrailDust; 05-12-2011 at 04:38 PM. Reason: Removed photo from quote.
grandpapa is offline   Reply With Quote
Old 05-12-2011, 12:11 PM   #7 (permalink)
Toyota Freak
There is that. I just didn't like what I looked at. And I'm very happy with the '11 Highlander.
Old 05-12-2011, 12:29 PM   #8 (permalink)
RectangleAmericaMegaphone
View 9volt's Photo Gallery
Most people that buy SUVs would probably be better off with a minivan. Other than hating that they are driving a minivan.
9volt is offline   Reply With Quote
Old 07-10-2011, 01:29 PM   #9 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
Canada
I am hoping to take my middle passenger side out to provide space for a cooler. Did you obtain any TIS instructions or just use common sense?
I see that your platform is raised a bit, is this because when the seats come out the floor is still not smooth / flat?
Removing the seats in my minivan to provide floor space was so easy I did it all the time.. on my HL perhaps not so often
Ralph6410 is offline   Reply With Quote
Old 07-10-2011, 03:52 PM   #10 (permalink)
Toyota Freak
I'm very handy but I did need the TIS instructions to unclip the cable.
Right. The HL floor is not flat. The HL comes up around the rails that the seats move on and even there it is uneven. I rarely carry more than my wife but often I need to move an awkward cargo. So now, it's everything I need.
Ralph6410 (07-10-2011)
