Yes, what happened is perfectly normal. The HL has a central differential that distributes torque 50/50 between front and real wheels. This means that if one axle is allowed to spin with essentially no resistance (like the rear wheels on frozen mud), there is very little torque going to the other axle.
Some all-wheel drive cars have a system that applies brakes to the spinning wheel to create additional resistance and transfer more torque to the sheels with traction. Not sure if HL has it. Anyway, this system is usually effective if only one wheel is spinning, but turns pretty ineffective if two or three wheels have no or little traction. Other cars have a torque-biased central differential that sends more torque to the wheels that are turning slower (or not turning at all). This system was first implemented in Audi Quattro. It is better than a simple differential, but still requires at least some level of traction on all four wheels - if one or two wheels are spinning completely freely there will be no torque delivered to the other wheels either.
The HL 4WD system isn't really a true off-road type 4-wheel drive system. It is intended to provide additional traction on slippery roads, but it's not comparable to a true 4x4 system with torque-biased or lockable central differential (like the one you can find in a Toyota Land Cruiser, 4Runner or FJ Cruiser). Remember, HL is a "crossover" (i.e. a car disguised as an SUV), not a real truck-based SUV.
A good example of an excellent four wheel drive system is like the one implemented in Toyota Land Cruiser and FJ Cruiser (manual transmission). It is a full-time four wheel drive with a torque-biased central differential. Under normal conditions, the torque is split 70/30 between rear and front wheels. If one axles losses traction, up to 90% of the torque is delivered to the axle that has good traction. There are no electronics involved and the response is instantaneous. If this is not enough to get you moving, the electronics kick in and apply brakes to the wheel(s) that are spinning faster, creating additional resistance and directing more torque to the wheels with traction. But if the electronics are not "smart" enough to get you going, you can mechanically lock the central differential (and the rear one) so that 100% of the torque can be delivered to a single rear wheel or to the front axle. Stock Land and FJ Cruisers don't have lockable front differential which would create the ultimate traction option (100% torque delivered to ANY wheel), but it can be added as aftermarket option. In practice it's rarely needed unless you engage in extreme rock crawling / mudding. I think 4Runner has similar system, but I'm not sure.
The downside of a "real" four wheel drive system is that everything in the drivetrain must be oversized to handle the possibility of all torque/power going to a single wheel. I have both the HL and FJ, and although the FJ is lighter and has less horsepower than the HL, all drivetrain components (differential, drive shaft, etc.) are at least 50% bigger (and heavier).
