trailer hitch ?s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2010, 08:23 AM   #1 (permalink)
View recurve's Photo Gallery
trailer hitch ?s
Hi folks,
Looks like I'll be getting a 2010 base HL - got a decent year end deal.
It has the trailer prep pkg. and I plan on putting on a hitch for bike racks, steel grate-type gear carrier, etc. No plans to pull a trailer now though I would like to wire it just in case.
Searched here and watched some installation videos - seems like a straight forward process but does anyone spray undercoating into the nut holes or between the hitch and frame?
Also any pros/cons on the brands of hitch (Curt, Valley etc) and installation tips would be appreciated.
Thanks again for your comments.
recurve is offline   Reply With Quote
Old 12-09-2010, 10:59 AM   #2 (permalink)
Dman1's Avatar
Gameroom cash: $135752
View Dman1's Photo Gallery
Originally Posted by recurve View Post
Hi folks,
There are lots of threads on this. Just do a search for 'hitch'.
IMO, the OEM looks the best, but unfortunately costs about twice as much. The after market hitches are a couple inches closer to the ground than the OEM. I have the OEM hitch and have absolutely no regrets.
2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
Dman1 is offline   Reply With Quote
Old 12-12-2010, 07:31 AM   #3 (permalink)
Thanks,
If you get a chance could you tell me the measurement from the top of the hitch opening to the ground? They give this measurement on the aftermarket hitches and this will help me compare the OEM to aftermarket. No HL in the local lot had factory installed hitches for me to measure.
Thanks again.
Old 12-12-2010, 08:29 AM   #4 (permalink)
Dman1's Avatar
Thanks,
Thanks again.
It's approximately 17.5" from the ground to the outside top of the 2" receiver (that's in my garage on a level concrete floor, so it should be quite accurate). I believe that it sits 2-4" higher than the aftermarkets. If you haul a camper, I would recommend the OEM for the extra height, because some campgrounds can have some challenging terrain that would cause parts of your setup to drag on the ground at times.
Old 12-12-2010, 02:29 PM   #5 (permalink)
View ROMAFERN's Photo Gallery
Hey Dan,
do you happen to know the part number of the OEM hitch? My wife's 2011 HL AWD V6 SE has the installed towing package but without the hitch. I am not sure why in hell is Toyota not including the hitch in the package. I would not mind paying for it....
I am also in the market for a hitch and I you would not mind, can you post some pictures of the back end of your Lander?
Thanks buddy.
Rob
ROMAFERN is offline   Reply With Quote
Old 12-14-2010, 11:06 AM   #6 (permalink)
Dman1's Avatar
Originally Posted by ROMAFERN View Post
Hey Dan,
Thanks buddy.
Rob
Sorry I never got the chance to do this. I see that you found a few other threads and replied on there. Lots of good pics there too. Good luck.
