Originally Posted by sneaky262
Yes! That's what I'm after... Do you have any suggestions or regrets on the Viper? That's the one I'm leaning towards at this point.
-Byron
No regrets whatsoever. It has more features than I need (like auto start if temp drops below certain temp, etc etc.) but as far as security and auto start, which is what really matters, works perfectly.
The only issue to consider is whether you have push button start. I don't....actually one of the several reasons I went with the Sport rather than the Limited. Push button is a bit of a challenge, and may require carrying two fobs around. Not sure if there is a bypass for this now or not.
If no push button, you will need a bypass for your chipped key however...that usually runs another $80 - $100.
Key to it all - a reputable installer you can trust - and hopefully one that solders all connections. Can't stress this enough.
Cheers.
