This newbie needs help with Towing Package. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2010, 01:47 PM   #1 (permalink)
View CraigerB's Photo Gallery
My 2010 HL LTD was supposed to come with a Towing Package, (includes 5000lb towing capacity, heavy duty radiator with engine cooler, 240-watt fan coupling, transmission oil cooler with water cooler, 150-amp alternator and prewired harness). My question is, how can I be sure this was actually installed? I kind of have my doubts this was included in my option package even though I paid for it.
Hope somebody can help.
Thanks.
CraigerB is offline   Reply With Quote
Old 12-20-2010, 05:54 PM   #2 (permalink)
View roadrunner117's Photo Gallery
One thing you can easily check is the oil filler cap. I believe 2008-2010 models with the towing package use 5w30 oil, and models without the towing package use 5w20 oil. What does your oil cap say?
2011 Highlander Base 4WD V6, Sizzling Crimson Mica
roadrunner117 is offline   Reply With Quote
Old 12-20-2010, 08:56 PM   #3 (permalink)
View nov0798's Photo Gallery
Look at the build sheet from the factory, match the vins, and whatever it says you should have.
nov0798 is offline   Reply With Quote
Old 12-21-2010, 09:54 AM   #4 (permalink)
View Propman's Photo Gallery
Thanks.
I have a 2010 Base 4wd V6 with tow pkg. I took a picture of the front divers side showing the vent for the transmission cooler. Also, open the fuse box in the engine compartment and look at the fuse box and the ALT fuse should be 140amp.
Propman
Last edited by TrailDust; 12-21-2010 at 11:57 AM. Reason: Photo link edited to assist viewing.
Propman is offline   Reply With Quote
Old 12-22-2010, 07:44 PM   #5 (permalink)
Dman1's Avatar
Gameroom cash: $135752
View Dman1's Photo Gallery
Thanks.
I see that you are from Vancouver. Seeing as how you are close to the US border, did you buy your HL in Canada or did you go stateside? If you bought it in Canada, while I am not 100% sure of the 2010 models, all 2008 and 2009 models built in Japan and sold in Canada with the 3.5L V6 come standard with the towing prep package. Again, I am not sure if that is still the case with the 2010 and 2011 models, and I am not sure if that changed when they started building them in the US.
I went through the same frustration and confusion when I first purchased my HL.
2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
Dman1 is offline   Reply With Quote
