Originally Posted by Financeman
Have you purchased new tires that have a higher rolling resistance than the originals? Perhaps tire inflation levels are a bit low...though I would think the low pressure warning light would illuminate if this were the problem.
No, I have same tires which came with the vehicle (I have Toyo tires)
Originally Posted by jeffs3820
What is the road condition? Dry? Wet? Snowy? Was car warmed up? Make sure emergency brake is disengaged.
Road condition is dry and sometimes wet due to snow.
Originally Posted by MikeyD25
While I don't recommend doing this at high speed, or for a long length of time, have you tried coasting with the transmission in neutral (N) to see if the same condition exists?
What you're experiencing could be the vehicle's on-board computer (ECM) shutting off the fuel to the injectors while your foot is off of the accelerator and the vehicle is in gear to make your H/L more fuel efficient.
Just my .02!
MD
I also tried your suggestion: I tried going at 60-65mph on the highway and then took the foot of the gas pedal and saw rapid deceleration.
One day in the city driving at went a 40-45 mph and then took the foot of the gas pedal and saw rapid deceleration. I wanted to see how far it goes deceleration wise and I have noticed that when it hit +/- 20 mph, it observed that it started rolling freely and I was pleasantly surprised.
Originally Posted by nickhl
You may need to check whether your handbrake/parking brake is properly disengaged. With stock Toyo A20, I have to say my HL really won't slow down much in coasting condition. As a result, I have to brake a lot more than my previous Mini Cooper S automatic (which slow down as soon as I'm off throttle) when approach traffic light stop/in traffic.
Handbrake/parking brake not engaged.
Things to know about my driving habits:
I am very light footer in terms of pressing the gas pedal. I never or try my best not to cross 2000 RPM under most circumstances. While entering the highway, I may reach 2500-3000 rpm and settle down again at 2000 RPM or so and maintain speed at around 60-65 mph (highway) and 30, 40-50 mph normal driving etc.,
I do put my feet on the brake pedal but making sure I am not pressing the brakes.
Whatelse to do??
I took my car this saturday to the Dealer (Boch Toyota) and they inspected and found nothing wrong with it at all
Please share your thoughts...
Also, please forgive because I am slow to respond these days, Thank you all
