4cyl-awd? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2010, 08:09 PM   #1 (permalink)
View dslkdl's Photo Gallery
4cyl-awd?
bought a 2009 highlander sport, can you get a 2009 highlander with a 4cyl and AWD?
Thanks
dslkdl is offline   Reply With Quote
Old 12-29-2010, 07:59 AM   #2 (permalink)
View nickhl's Photo Gallery
Thanks
Nope.
nickhl is offline   Reply With Quote
Old 12-29-2010, 03:07 PM   #3 (permalink)
View typesix's Photo Gallery
2nd generation Highlander can't be had with 4 cyl and awd, only 1st generation.
typesix is offline   Reply With Quote
Old 01-03-2011, 09:51 AM   #4 (permalink)
Francois L'Ollonais
lollonais's Avatar
View lollonais's Photo Gallery
Too much stress on the engine in my opinion.
2007 Black Camry CE
20% Black tints, Prestige Alarm with Solenoid for Trunk
2009 Pearl White Highlander Hybrid Limited
Navigation Package OEM everything except overhead DVD
lollonais is offline   Reply With Quote
Old 01-03-2011, 05:06 PM   #5 (permalink)
summerwind's Avatar
Gameroom cash: $450530
View summerwind's Photo Gallery
My experience has been that to handle the weight of a vehicle the gear ratio on 4 cylinder Engines has to increase the gear ratio over a V6. In the long run the difference in mpg is not that great and that cost difference in gas over a annual basis is insignificant.
If cost per mpg is a high priority then a HL is not a good choice.
I bought my HL for what it is and did not expect high mpg compared to a Prius.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 01-04-2011, 01:35 PM   #6 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
The Venza is available with a 4cyl/AWD. Highlander V6/AWD is only 250lbs heavier. 100lb difference due to engines and a Highlander I4/AWD would only weigh 150lbs heavier than the Venza. Toyota hasn't suffered enough in sales to offer it yet.
More gears in the transmission can make up for the final drive ratio. The 2.7L/6-speed auto would work fine. We're depressed by the 5-speed auto with the V6.
And, the 2.5L in the RAV4 is rated to tow 1500lbs with a weight of ~3500 pounds. The 2.7L should not have a problem moving the Highlander around for the majority of non-lead-footed drivers.
With the economy the way it is, not sure why the 2.7L isn't offered with AWD. I think it would have good sales volume. And, I was disappointed when the 3.3L was replaced by the 3.5L in the hybrid. The 2.7L would've been perfect replacement for the 3.3L. I'd buy a 2.7L Hybrid AWD instantly if it was offered.
I think that Toyota is trying to keep the 'upscale' image of the Highlander. I thought that, that is what Lexus is for. They did dump the V8 in the 4runner already. But, the Landcruiser, Tundra, Sequoia are now bloated pigs with lipstick. Instead of sticking with their roots, they blindly jumped on the same road as GM. Hopefully they pull a u-turn soon.
deadrx7conv is offline   Reply With Quote
