Need help with the climate control recirculation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2011, 07:00 PM   #1 (permalink)
View PhantomZX's Photo Gallery
I just picked up an '11 Base last weekend and I'm getting pretty annoyed at the recirculate button automatically turning off (going to outside air) after 3 minutes. It's pretty cold outside here, and I don't like cold air blowing at me suddenly when I'm driving on the freeway. Anyone got any tips on how to keep the climate control in recirculate mode permanently?
PhantomZX is offline   Reply With Quote
Old 01-07-2011, 07:20 PM   #2 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535595
View 05Moose's Photo Gallery
It turns recirc off automatically (giving you fresh air) to avoid your windows fogging up when the temp falls below a certain point. I've heard that point is anywhere from 48 to 56 degrees). If you hold the recirc button for more than 5 seconds, it will override the setting. However, once you turn the vehicle off, it goes back to its auto mode and you'll have to hold the button again to override it.
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline   Reply With Quote
The Following User Says Thank You to 05Moose For This Useful Post:
PhantomZX (01-07-2011)
Old 01-07-2011, 07:34 PM   #3 (permalink)
I'll try it out on my drive home tonight. Looking forward to keeping warm!
Old 01-07-2011, 08:54 PM   #4 (permalink)
Got Snow?
05Moose's Avatar
I'm still curious as to why you need it on recirc for heat rather than using the temperature dial. Let the fresh air come in and set the temp where you want it. That's what we do.
Old 01-07-2011, 10:06 PM   #5 (permalink)
The car's engine takes a few minutes to warm up, so the heater doesn't even work at that point. I'd also rather not have any air blowing at me, whether it be cold or warm. At freeway speeds, there's quite a lot of "wind" in fresh air mode.
Old 01-07-2011, 10:08 PM   #6 (permalink)
Got Snow?
05Moose's Avatar
Ah, gotcha.
Old 01-07-2011, 10:12 PM   #7 (permalink)
Forgot to mention, the tip of holding recirc for 5 seconds works! Got home without any annoying blast of wind in my face. Wish I didn't have to hold it down every time though
Old 01-07-2011, 11:18 PM   #8 (permalink)
Toyota Freak
Gameroom cash: $105200
View earthltd's Photo Gallery
Had the same problem with the cold air coming back on before my '11 Base warmed up. Figured it out from reading a thread on another topic where the cure was also holding the button down for a few seconds. I now expect to find that feature on more controls. Sometimes the control doesn't reset after turning the engine off so I'm still partially confused about it's operation. It must depend on one of the related settings. Like how it won't go into recirc when in Defrost mode. (Forgot that I had left it on.)
earthltd is offline   Reply With Quote
Old 01-08-2011, 05:39 PM   #9 (permalink)
Now - 2011 Explorer Ltd
peterk9's Avatar
View peterk9's Photo Gallery
I have an '09 HL Ltd but I don't have that problem. The one I do have is in the summertime, even with the outside air temp being cooler than inside, the recirc comes on. Apparently the recirc program can be changed to manual control but it has to be done by Toyota service personnel. When I first got mine, I had it written into the deal to have the recirc programmed to Manual operation. Unfortunately they were not able to do it before I picked it up and was told to bring it back later. Have never gotten around to doing it. I know someone else that had the reprogramming done on his '09. I'm sure the same can be done for 2011 model.
Peter
Lease Transferred - Canadian '09 HL Ltd, Classic Silver Metallic with Nav, ash interior, body side moulding, hood deflector, Camry trumpet horns, Philips X-Treme Power bulbs, Toyota 3 piece rubber floor and cargo mats. My 2011 Explorer Limited has arrived.
peterk9 is offline   Reply With Quote
Old 01-09-2011, 11:08 AM   #10 (permalink)
View MikeyD25's Photo Gallery
RECIRC is also very beneficial when driving in a tunnel. Whether on AC or HEAT, RECIRCULATE will keep any unventilated tunnel fumes out of the passenger compartment. This is a necessity especially when you get stuck in a tunnel 'traffic jam'!
MD
In memoriam NYPD DAOS / NYS OIG #77
'12 Highlander SE - Sizzling Crimson Mica / Black Interior / V6 / 4WD + Tow Prep Pkg; OEM Mud Guards; OEM All-Weather Mats; Camry horns; Weathertech Vent Visors & AVS Bugflector II.
'09 RAV4 Base
- gone.
'06 Highlander Base
- gone.
R.I.P Seattle Mike / Joe S.
MikeyD25 is offline   Reply With Quote
Old 01-19-2011, 06:04 PM   #11 (permalink)
View mtbeesen's Photo Gallery
So glad to hear there is a way to avoid the automatic recirculation problem. It is my only issue with the 2007+ Camrys. I would rather manually control the recirculation to avoid inhaling fumes from the car in front of me.
mtbeesen is offline   Reply With Quote
