Power Outlets Not Working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2011, 08:59 AM   #1 (permalink)
View Ruggie's Photo Gallery
Hi there,
This is my first post as I have just brought my first Highlander (OK Kluger but...).
It is a 2008 version, Grande and none of the power outlets work, not the one in the rear or the two in the front.
I have checked the fuses (in the engine and under the dash x2), tried different leads in to the power outlets (with the engine running) but all with no luck.
Am I missing something obvious?
I've searched the forum(s) but to no avail....
Thanks in advance,
Richard.
Ruggie is offline   Reply With Quote
Old 02-04-2011, 11:00 AM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Did you turn on the switch on the left side of the dash?
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-04-2011, 06:34 PM   #3 (permalink)
Thanks! Nope - where do I find this switch?
Old 02-04-2011, 09:15 PM   #4 (permalink)
View jeffs3820's Photo Gallery
The switch on the left side of the dash is for the AC outlet in the rear that comes with the factory DVD player. I believe Richard means the 12V outlets. If all of them are out it has to be a fuse.
2008 Highlander Hybrid Limited; Nav, DVD (His)
2007 Volvo XC70 (Hers)
1999 Camry LE (mine, used by my son)
jeffs3820 is offline   Reply With Quote
Old 02-05-2011, 08:51 AM   #5 (permalink)
Need For Speed
^Sorry, thought he meant the power outlet.
He said he checked all the fuses though.
Old 02-05-2011, 06:13 PM   #6 (permalink)
View 2SONHL's Photo Gallery
Will admit to limited knowledge of 2008's. But the wifes 2010 outlets are not hot all the time. The fuses for those outlets are fed by a relay that is actvated when the vehicle is turned on. So it may be a bad relay that is responsible for your problem. Unfortunately I do not have a diagram that reflects which relay it is or even where the relay is. Learned just enough about it to come up with a mod to make one of the outlets on her car hot all the time. Anyone out there have the answers?
2SONHL is offline   Reply With Quote
Old 02-06-2011, 04:31 AM   #7 (permalink)
View thesson's Photo Gallery
On the 2010 (what I have), it looks like the 12v ACC relay is under the dashboard. There should be five along the bottom front edge and the ACC should be the center one. I don't know how the get to it though other than taking the dash panel off.
thesson is offline   Reply With Quote
Old 02-06-2011, 05:54 AM   #8 (permalink)
Thanks all for your input. I have solved it.
I agree that it most likely had to be the fuse so despite the fuses "looking" OK I today went and brought a pack of replacement fuses (my mulitmeter is still en-route in the container to Australia!).
The replacement fuses have fixed it. Strange that both had gone, but I guess the previous owner must have overloaded them somehow (ice box perhaps??)....
On an aside I installed the Grom Ipod unit - easy to fix and the sound quality is great.
Thanks all.
R.
