Seafoam (2gr-fe) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2011, 06:52 PM   #1 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
Seafoam (2gr-fe)
Ok so i have found basically nothing concerning seafoam and the engine in our highlander. I found 1 video on youtube about it (with our engine, actually on a camry), but does anybody have any experience with this on their cars? I know to use the brake booster vacuum line (i think thats whats its called, but i know where it is on the engine), and use 1/3 of the can there, but i am a bit hesitant. I have read plenty of posts about how good it is, others say its bad... any info would be great thanks
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 02-25-2011, 08:44 PM   #2 (permalink)
Gameroom cash: $195050
View rupert08's Photo Gallery
I have used Seaform as a fuel stabilizer in my seasonable engines but never in my daily vehicles. I would consider using it on a 10 year old engine if it wasn’t running well but not in a 3 year old vehicle that has no issues.
rupert08 is offline   Reply With Quote
Old 02-25-2011, 08:47 PM   #3 (permalink)
sweeneyp's Avatar
yea i figured it might be soon, i was just thinking prevent buildup, not clean it once it builds, considering it already has 55k miles on the engine. I might be jumping the gun on this though
Old 02-26-2011, 08:15 AM   #4 (permalink)
View caf2461's Photo Gallery
I have used seafoam on older engines. It really helped the miata's I owned but they all had over 120k on the engine before I used it. Basically you meter Seafoam into the engine through an upper intake vacuum fitting by using vacuum line and an adjustable clamp. Lots of smoke - Kills lots of bugs in the neighborhood. Takes a couple drives around the block to clear it all out. The end result was less pinging and better pick up.
What worked better than Seafoam is the GM combustion chamber cleaner (available only at dealers).
I don't think your Toyota needs this level of treatment. It takes a while for carbon deposits to become a problem.
I have had good luck with running Liqui Moly Intake & Valve cleaner as a preventative measure on my other vehicles. This was just added to the gas tank during the fill up previous to an oil change at about 60K, 90K, 120K miles.
caf2461 is offline   Reply With Quote
Old 02-26-2011, 11:13 AM   #5 (permalink)
sweeneyp's Avatar
thats interesting about the GM combustion cleaner, ok i guess ill just wait then, thanks
