20 inch MRR HR2 wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2011, 10:53 PM   #1 (permalink)
View fkong777's Photo Gallery
Just ordered some upgrades.
-9003 / H4 8000k hi/lo slim ballast HID kit
-20" MRR HR3 wheels.
will be going with 275/45/20 tires prob get tires in a couple weeks.
Future upgrades-
JVC - NT3 indash nav unit
Eclipse - 6x9 component speaker system
Kenwood - ksx sw10 powered sub.. or make a custom box for the center console storage compartment.
2 headrest LCD w dvd player.
fkong777 is offline   Reply With Quote
Old 02-25-2011, 11:56 PM   #2 (permalink)
bingo883's Avatar
View bingo883's Photo Gallery
Nice wheels.
What are the offset on these?
It will be perfect if they stick out flush to the side of the wheel well.
I am not sure if I can ever do that to my 19".
Also, please keep us posted on your 6x9 component upgrade.
I want to do that as well on my jbl system.
Good Luck!!!
bingo883 is offline   Reply With Quote
Old 03-06-2011, 01:26 PM   #3 (permalink)
Gameroom cash: $145500
View nogo's Photo Gallery
Please post up pictures when you mount them. Also some specs would be appreciated:
- Wheel width
- Offset
- Which tires / size did you finally go with?
- Wheel / tire weight
Thanks
1997 Jetta GLS, 2007 E280 4Matic, 2010 Highlander Sport
nogo is offline   Reply With Quote
Old 03-06-2011, 05:24 PM   #4 (permalink)
View sanf's Photo Gallery
keep us posted with pics...
sanf is offline   Reply With Quote
Old 03-06-2011, 07:54 PM   #5 (permalink)
luck123's Avatar
View luck123's Photo Gallery
Nice by the way....I like the look, but not sure my aging body could deal with the rougher ride of a lower profile tire.
Have you done a test fit? Only reason I ask is because when I was looking at getting aftermarket winter wheels, I found that the tire (not the wheel) in the rear is very close to the strut. I note that the MMR wheels are 35 offset, same as OEM, but because they are 8.5 inches instead of the OEM 7" wide, they will pull the tire closer to the strut. Given the tire is 30 mm wider (275 vs 245) , the inside will be 15 mm closer to the strut. Hopefully there is sufficient clearance.
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
Old 02-16-2012, 11:11 PM   #6 (permalink)
Finally got them on. running 255/50/20 and 275/45/20
Looks better, Not Awesome or Great but better than the 17" SE wheels.
Need a Wash. Just dried from recent rain.
RE- Ride quality. Not that much difference.
Specs
20x8.5 +35 (25mm hubcentric spacer) 255/50/20
20x9.5 +45 (25mm hubcentric spacer) 275/45/20
It needed at lease a 10mm spacer for the 9.5" +45 rear. front clears the 8.5" +35 without issues.
but I when ahead and got a 25mm spacer for front and rear. So much room in the HL wheel well.
with spacers, front offset is adjusted to 20x8.5 +10 and rear 20x9.5 +20
If you run without spacers the rear go with 9.5inch +35 or lower offset. or got 8.5ich +35 or lower for all 4 wheels
No rubbing at all.
08 Blue Streak HL4x4, HID, 20" MRR HR2
00 ML55
91 NSX
02 S430
The Following User Says Thank You to fkong777 For This Useful Post:
nogo (02-17-2012)
Old 02-17-2012, 09:05 AM   #7 (permalink)
Thanks for the pictures and the details. Wheels look similar to the OE 19" wheels but fill out the fenders nicely.
Old 02-17-2012, 04:44 PM   #8 (permalink)
New TN CEO
victorglinsky's Avatar
View victorglinsky's Photo Gallery
I got mine with 265/50R20s. No spacers, no rubbing
- Wheel width 8.0
- Offset 40
- Which tires / size Yokohama Parada Spec-X 265/50R20
- Wheel / tire weight 36 lb[
http://www.toyotanation.com/photos/s.../ppuser/259953
some trust in MPG and some in horses...
2012 Highlander Limited 4WD
victorglinsky is offline   Reply With Quote
Old 03-29-2012, 01:39 AM   #9 (permalink)
Just washed, Clean pics
00 ML55
91 NSX
02 S430
Old 03-30-2012, 01:59 AM   #10 (permalink)
New TN CEO
