DRL disable DIY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2011, 01:38 AM   #1 (permalink)
View fkong777's Photo Gallery
DRL disable DIY
Update Sorry folks for wasting your time. my information below didnt work.
Just found a couple of DIY on DRL disable from ClubLexus;
I will be doing one of the following since I will be installing HID's
my 2008 HL have the a similar relay block with similar orange 5-pin relay.
Oem Part # is 90987-04004
the following should retain the auto function on the headlights without DRL.
RX series 2nd Gen - DRL relay change with pics:
http://www.clublexus.com/forums/rx-s...-pictures.html
RX series 2nd Gen - DRL relay block wire pull
http://www.clublexus.com/forums/rx-s...tructions.html
Cheers
08 Blue Streak HL4x4, HID, 20" MRR HR2
00 ML55
91 NSX
02 S430
fkong777 is offline   Reply With Quote
Old 02-28-2011, 01:10 PM   #2 (permalink)
Gameroom cash: $113755
View jimmied's Photo Gallery
OR you could just ask the dealer to quickly program it for you.
2008 4runner
2009 Venza - wifey's
jimmied is offline   Reply With Quote
Old 02-28-2011, 08:08 PM   #3 (permalink)
View sanf's Photo Gallery
Thanks ~
sanf is offline   Reply With Quote
Old 02-28-2011, 09:03 PM   #4 (permalink)
i just looked at my 08 relay panel. the layout is different and it reads "deicer". so that very same relay might not be the DRL one. might want to double check
