Originally Posted by sweeneyp
I'd imagine you want to wire them into the interior lights circuits (so that they come on when you unlock the car or open the door), though unfortunately i don't know where you can tap into that circuit. Hopefully someone can help.
Like sweeny said with the interior light cicuit, I would try to take out the dome light, use a multimeter to check for 12 volts when the door is opened then hook up a wire and fish it down from the domelight to the underdash area. Look for somewhere in the firewall where you could run the wire through and hook it up to the sidestep light. Find a good ground and run it also to the sidestep light. I'm assuming theres only 2 wires for the sidesteps. If theres not enough voltage at the dome light you might need to wire up some sort of relay. If if seems too involved for you just bring it to a shop, I don't see them charging you more than an hours worth of labor for it.
