Steering Wheel Control Install Question (PAC or Axxess) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2011, 11:13 PM   #1 (permalink)
View azonicdh's Photo Gallery
I am doing some pre-research for my steering wheel control before I install my new headunit. Both the PAC and Axxess instructions tell you to connect some wires to a 20 Pin connector in the HL, but the audio harnesses I have are a 6 pin and 10 pin. Is there another 20 pin connector behind the dash? Where does it connect to and will I be able to T-Tap the wire needed? I currently have a stock, non JBL unit.
azonicdh is offline   Reply With Quote
Old 03-13-2011, 08:59 PM   #2 (permalink)
View rguin's Photo Gallery
20 pin connector
The 20 pin connector they are referring to is in your dash. You will see it when you pull the stock unit.
rguin is online now   Reply With Quote
