Toyota's 2 yr maint. agreement confusing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2011, 06:50 PM   #1 (permalink)
View craftydad's Photo Gallery
I got a 2yr or 25K mile free maintenance agreement with my new '11 HL. The booklet and card that explains it came in today. It states I get an oil change every 10K miles, and it says "synthetic" for oil type. This is strange because I have never used synthetic oils in my cars. I checked the Maintenance book that came with the car, and sure enough, it states an oil change every 10,000 miles and that 0W20 should be used. I had a coupon for a free oil change (from Toys for Tots drive) and I used it to get an oil chaange at 1500 miles to clear out the new oil. I don't know what oil they put in the car (paperwork does not state) but the oil cap says 0W20 on it.
Is 0W20 oil synthetic??
Hers: 2011 Sandy Beach Metallic Highlander Ltd with Nav, color keyed crimp-on door guards, side moldings with chrome stripe, mud guards, hitch, bug deflector, exhaust tip, roof racks, rain guards, all-weather mats, envelope net, Wolo horns.
His: 2000 Salsa Red Sienna XLE
craftydad is offline   Reply With Quote
Old 03-28-2011, 08:34 PM   #2 (permalink)
View jeffs3820's Photo Gallery
Yes, my understanding is the only way to get 0w20 is if it is synthetic.
2008 Highlander Hybrid Limited; Nav, DVD (His)
2007 Volvo XC70 (Hers)
1999 Camry LE (mine, used by my son)
jeffs3820 is offline   Reply With Quote
Old 03-28-2011, 08:48 PM   #3 (permalink)
And it's normal to have oil changes at 10K miles with synthetic?
Not that I'm complianing... but Toyota should have given owners a choice... not decide for us that all 2011 HLs will use syntheic.
Old 03-28-2011, 09:04 PM   #4 (permalink)
bingo883's Avatar
View bingo883's Photo Gallery
Here is an interesting read... enjoy!
http://www.smartsynthetics.com/articles/5w20oil.htm
bingo883 is offline   Reply With Quote
Old 03-28-2011, 09:22 PM   #5 (permalink)
View Alpha Zero's Photo Gallery
While that article looks pretty convincing; I'm way too lazy to research it further.
It may very well be correct in everything that it claims and such, but ending an article with a link to purchase said motor oil which they claim is the BEST takes away from it's validity.
Alpha Zero is offline   Reply With Quote
Old 03-28-2011, 09:23 PM   #6 (permalink)
View TECH 1's Photo Gallery
If the vehicle has sythentic in it then you have to put sythentic in it. It can not be changed to conventional or a sythentic blend oil. The engine will blow up. However if you have conventional oil in a vehicle, you can use sythentic oil. Hope this is some help to you.
TECH 1 is offline   Reply With Quote
Old 03-28-2011, 10:27 PM   #7 (permalink)
View horent135's Photo Gallery
LOL, engine will not blow up.. It just not recommended from going synthetic to conventional oil, mostly the engine won't run good as before.
horent135 is offline   Reply With Quote
Old 03-29-2011, 06:49 AM   #8 (permalink)
View vsansal's Photo Gallery
It is interesting because my 2010 has 5k mile oil change intervals. They must have changed it on 2011.
vsansal is online now   Reply With Quote
Old 03-29-2011, 07:10 AM   #9 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
If I were you I would switch to the 2008-2010 recommended "dino" blend and switch to 5k intervals.
The car is so new that switching won't hurt a thing. If you have a 1988 Toyota Tercel with 300k which you had been using dino oil and then switched to synthetic you might notice some oil leaks that were present but not as noticeable before.
JMSinMD is offline   Reply With Quote
Old 03-29-2011, 09:16 AM   #10 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Toyota is going to 0w-20 on ALL their models eventually. The 0w-20 is new for the 2011 Highlander, and is certified only as such. Toyota says if 0w-20 is not available, you may use 5w-20, but you MUST change the oil after 5,000 miles with 0w-20.
My 2011 Camry also uses 0w-20 exclusively. A tech friend of mine here at the dealership did an experiment, using 5w-20 and 0w-20, and he consistently got better gas mileage using 0w-20 vs. 5w-20.
Using 5w-20 in your new Highlander will not blow up your engine, but if it's all you use and you have a problem down the line more than likely Toyota will not honor any warranty.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 03-29-2011, 09:25 AM   #11 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535495
View 05Moose's Photo Gallery
10K miles is not a big deal using synthetic. Regular Oil is good for a minimum 7500 miles (our old '04 Sienna's maintenance schedule by Toyota was 7500 miles using conventional oil and even Calif tests show that regular oil lasts a minimum 7500 miles in all vehicles). If auto manufacturers are recommending 10K mile change intervals using synthetic oil, then it's probably good to a minimum of 15K miles. I do wonder though if their tests are showing that the oil filters are good for a minimum of 10K miles now?
Edit: I though there are only 2 Toyota models that have not yet switched to the 10K mile oil changes: Tundra and Tacoma, but based on arabianobsession's link below, I stand corrected:
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is online now   Reply With Quote
Old 03-29-2011, 09:26 AM   #12 (permalink)
Need For Speed
^That is not correct
Synthetic Oil Update
Old 03-29-2011, 09:28 AM   #13 (permalink)
Need For Speed
The 4 cylinder Tacoma takes 0w-20 Synthetic but the intervals are still every 5,000 miles per Toyota.
Old 03-29-2011, 09:29 AM   #14 (permalink)
Got Snow?
05Moose's Avatar
I stand corrected. I thought we just had this discussion over on TW a couple of weeks ago? Guess my mind is playing tricks on me.
Old 03-29-2011, 09:31 AM   #15 (permalink)
Need For Speed
lol. It's all good.
It's difficult to keep up with all the changes Toyota has made recently, even for us at the dealership.
