Any way to make the rear power outlet un-switched? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2011, 07:57 PM   #1 (permalink)
View pgoelz's Photo Gallery
I fly electric model airplanes and for charging it would be great if the power outlet in the rear of the vehicle was always on. Anyone know if there is an easy way to do that? If not, I can always add a second outlet wired directly to the battery.
And before anyone asks, no I don't charge in the vehicle. I charge on the ground behind it
Paul
pgoelz is offline   Reply With Quote
Old 03-30-2011, 08:12 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
FWIW, check out this thread about power to the rear outlet, particularly post #9.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 03-30-2011, 08:37 PM   #3 (permalink)
Yeah, that solution is what I was thinking. That, or if the outlet is separately fused (I think it is), I could make up a jumper with an inline fuse and a blade from an old fuse, remove the existing fuse, and jumper the output end of the outlet fuse position to battery. That would convert it to always on and preserve the fusing without any additional wiring required.
Paul
