2011 HL adjust headlight help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2011, 08:52 PM   #1 (permalink)
View horent135's Photo Gallery
Where is the up/down adjustment for the headlight? Is there like a gauge level or something build-in around the headlight?
horent135 is offline   Reply With Quote
Old 04-12-2011, 11:09 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
Perhaps this past thread can help out some. Let us know if it's sufficient and works for you.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 04-13-2011, 09:57 AM   #3 (permalink)
I saw that adjustment on the HL, is there no adjustment that makes it move left/right? headlight I dont want get those confused... Plus there no level meter?
Old 04-13-2011, 10:54 AM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Hmm, I've never messed with my headlights so I can't say, but perhaps one of the other members has done it and can chime in.
2002 Avalon XL
Old 04-13-2011, 01:18 PM   #5 (permalink)
I mess with it, it is the same knob in the older models of HL, it does go up/down... Wrench setting to clockwise is down, and vice versa. It does not seem to have a level meter, so I just mark it with factory setting then begin to adjust it.
Hope this help others out there.
Old 04-13-2011, 10:49 PM   #6 (permalink)
View Alpha Zero's Photo Gallery
There is no level marker.
Park on level ground 25' away from a wall. The center of the headlight is roughly 35" from the ground (measure your vehicle just to be sure. Mines was 35"). At the wall, the beam should be at 33". Mines from stock was 37" so it was definitely off from stock. There is no left/right adjustment.
Alpha Zero is offline   Reply With Quote
The Following User Says Thank You to Alpha Zero For This Useful Post:
horent135 (04-13-2011)
Old 04-13-2011, 11:09 PM   #7 (permalink)
Thank you so much for that info!
Old 04-23-2011, 10:32 AM   #8 (permalink)
View Phatty McPatty's Photo Gallery
By law there is no left/right adjustment, only up/down.
Phatty McPatty is offline   Reply With Quote
