2011 Highlander LTD, front license plate mount - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2011, 09:18 AM   #1 (permalink)
View mhcchoi's Photo Gallery
Hello eveyone, I'm relatively new to this board but have recently purchased a new 2011 Highlander Ltd 4WD (American Express Auto Purchase Program Pricing is out of this world!!!). I have followed instructions on how to mount the mud guards and roof rack crossbars (great help here!!).. Anyways, I just received my NJ Plates and replaced the dealer 'plates' with real plates. When I did that, I notice that the front plates were mounted DIRECTLY TO THE BUMPER, ie the 'factory' dimples were still intact. The dealer literally put 2 self tapping screws into a brand new bumper!!! .. Is that what you guys experienced!!. OMG, I spend nearly $40 g for a truck and they cannot even supply a proper front licence mounting solution without damaging the front bumper !!.
Thanks
mhcchoi is offline   Reply With Quote
Old 05-12-2011, 09:29 AM   #2 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535495
View 05Moose's Photo Gallery
That's how it's done. Toyota puts dimples in the bumper and the dealerships across the country use self-tapping screws. What's worse is that over time it wears the paint off the front bumper where it rubs if you don't put something in between.
On the bright side, Toyota has finally learned to do what we've been doing for years with the rear plate. They're finally putting a piece of padding between the plate and the paint. I used to have to do that myself when they didn't put anything in between.
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is online now   Reply With Quote
Old 05-12-2011, 09:32 AM   #3 (permalink)
They didn't use dimple points
Thanks, thought so, but the Dealer didn't even use the dimple points, the just screwed 2 self tapping screws into the bumper .... I'm kinda pissed about that !!!!
Old 05-12-2011, 09:35 AM   #4 (permalink)
View DaMaDo's Photo Gallery
That sounds strange to me. My 2011 ltd came with a black plastic frame for the front plate. We don't need them in FL but it's sitting in one of the rear compartments if I want. I'm surprised they didn't use that on yours.
DaMaDo is offline   Reply With Quote
Old 05-12-2011, 09:46 AM   #5 (permalink)
Use of the front assembly
Correction, they did use the front license assembly but the top 2 screws were bolted through the license plate, the front assembly and through the front bumper (creating 2 new 'holes').
Thanks
Old 05-12-2011, 09:53 AM   #6 (permalink)
Oh wow, I thought the purpose of the frame was to go into the dimples, eliminating the need to drill through the bumper.
Apparently though, drilling through the bumper is the way it's done. Check this thread.
Old 05-12-2011, 10:48 AM   #7 (permalink)
View roadrunner117's Photo Gallery
One of the things I was excited about when trading in my '08 Highlander for an '11 is that Toyota now supplies a front license plate frame. When I took delivery, I was watching my salesman as he installed the front license plate. We noticed that there are actually 4 dimples in the front bumper, but weren't sure why. We needed to hold the license plate against the front bumper to see which set of dimples lined up properly to the license plate.
So mhcchoi, if you remove your front license plate and only see 2 dimples in your front bumper, then your dealer used the other 2 dimples when installing your plate. If you remove your front license plate and see 4 dimples, then your dealer installed it incorrectly. Hope this helps.
2011 Highlander Base 4WD V6, Sizzling Crimson Mica
roadrunner117 is offline   Reply With Quote
Old 05-12-2011, 11:21 AM   #8 (permalink)
Will check when I get home ..
I think you maybe right, I only saw 2 dimples on the lower portion of the bumper. If there are 4 then quite possibly they used the top 2 and I overreacted .. Thanks for you tip ...
Old 05-12-2011, 11:31 AM   #9 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
I picked up my highlander used from a Cadillac dealership here in Tennessee. The front license plate is not required in this state. When I got it, the dealership decided to mount a Cadillac plate (an advertisement basically) in the front screwing those 2 screws right in (where before I bought it, there was no plate). Needless to say I was pissed when I saw it. I always thought there were frames to mount the plates, not screws. Now you basically HAVE to have the screws or plate there, otherwise you have two massive holes in the bumper. Oh well another stupid action by toyota to cheapen their cars haha.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 05-12-2011, 12:13 PM   #10 (permalink)
RectangleAmericaMegaphone
View 9volt's Photo Gallery
These work well and look good
http://www.bumperplugs.com/BPindex.html
9volt is offline   Reply With Quote
Old 05-12-2011, 02:01 PM   #11 (permalink)
I don't know what truck I was thinking of, but I thought there were tabs that pulled out for the frame to go in.
I went to look at my front end and saw that there's 4 indentations in the bumper for self-tapping screws. I also saw on a couple of Lexus cars parked by my truck that they have the same deal.
Old 05-12-2011, 04:43 PM   #12 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
Thanks
Those idiots at Toyota still do this on many of their models. In order to save the front bumper on my Avalon and Highlander I mounted about 1/2-inch adhesive-backed foam on the license plate and then screwed it on. With a generic chrome license plate frame on the front of the plate the entire "assembly" keeps the plate and frame about 1/8 of an inch away from the paint, preserving it from damage and/or rust.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 05-12-2011, 08:22 PM   #13 (permalink)
It is what it is.. Sigh
Well, I came home and took off the front plate. There are only 2 dimples on the bottom of the front bumper. I placed the plate over the 2 dimples and the dimples were too close together. Also tried putting the plastic license plate 'holder' over the dimples and same thing. So my only conclusion was in order to put on the front plate, you needed to make 2 fresh holes (using self tapping screws) for the license frame holder and license to fit ....
Thanks for everyone's thoughts ...
Old 05-12-2011, 08:46 PM   #14 (permalink)
sweeneyp's Avatar
thats exactly what mine is like. those 2 raised spots are to keep the plate off the whole bumper. The top two screws were just self taping screws put right in the bumper.
Old 05-12-2011, 09:26 PM   #15 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
Canada
I picked up my 2011 HL a few days ago and there was a package with bracket and screws in the back for the front plate. There are 4 dimpled holes and my plate would match two of those. There are instructions on the plastic bag which I scanned ... but it seems I can not add attachments.. which I take to mean pictures. (figured it out... RTFM)
Ralph6410 is offline   Reply With Quote
