2011 highlander door edge guards - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2011, 08:09 PM   #1 (permalink)
2009 RAV4
View bd01's Photo Gallery
There is probably an answer to this somewhere on the forum, but i've not been able to find it. I just picked up a 2011 highlander limited (sizzling crimson mica) and purchased the Toyota OEM color matched door edge guards online. Everything I read says they're just compression type fittings, but I'm reluctant to push to hard for fear of scratching the factory paint on the door. Has anyone out there put these on? Do they just push on, require a little tap with a rubber mallet, or is there some type of lubrication i should put on first. thks
bd01 is offline   Reply With Quote
Old 05-21-2011, 06:57 AM   #2 (permalink)
Toyota Freak
Gameroom cash: $105200
View earthltd's Photo Gallery
I tapped with a rubber mallet. Sometimes more than tapped while 'guiding' with more force than I liked. But they are on and I have no doubt that they will stay on. If you look very close you can see a couple small scuff marks from when I had to smack it. I don't think that lube would help.
earthltd is offline   Reply With Quote
Old 05-21-2011, 09:28 AM   #3 (permalink)
Gameroom cash: $174015
View jgayman's Photo Gallery
I know this isn't the subject of this thread but I never understood what value the door edge guards offered. There is no way to put them on without damaging the paint/finish to some degree. If after a few years you have to remove them you will see what I mean. But most importantly, they seem to only protect the other guys car from me opening my door into it. Which, has never been a problem for me. My problem has always been someone else opening their door into MY car for which the edge guards do nothing.
jgayman is offline   Reply With Quote
Old 05-21-2011, 12:53 PM   #4 (permalink)
becks's Avatar
Gameroom cash: $126215
View becks's Photo Gallery
USA
Try putting a little liquid soap and water in the guard channel. That might help them slip on easier.
08 4WD HL Limited, Magnetic Flint/Ash Leather, Toyo OC HT's 255/55/19's, European Horns, Extended Step Plate On Rear, DeBadged All Around. No NAV/DVD, OEM Hitch with Color Matched Fascia.Höen Endurance Amber Fog Light Bulbs.
__________________________________________________ ___________________________________
becks is offline   Reply With Quote
Old 05-21-2011, 03:47 PM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
Use rubbing alcohol as a lubricant. Works slick as snot, but dries quickly with no residue.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 05-22-2011, 07:56 PM   #6 (permalink)
View craftydad's Photo Gallery
fwiw, he dealership that put them on for me (the metal ones) said they heated the up which made them more pliable. They used a work rag and rubber mallet to install them (ap the rag not the metal).
Hers: 2011 Sandy Beach Metallic Highlander Ltd with Nav, color keyed crimp-on door guards, side moldings with chrome stripe, mud guards, hitch, bug deflector, exhaust tip, roof racks, rain guards, all-weather mats, envelope net, Wolo horns.
His: 2000 Salsa Red Sienna XLE
craftydad is offline   Reply With Quote
Old 05-27-2011, 03:16 PM   #7 (permalink)
View Loudog2's Photo Gallery
You could call a clear bra installer and have him put strips on the edge of the door. I have this on mine. Can't even tell they are there.
Loudog2 is offline   Reply With Quote
