2011 Fog Lights DIY change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2011, 06:32 PM   #1 (permalink)
View philly001's Photo Gallery
Hello:
Could you please advise the easy access to change bulbs on fog lights for 2011? Is there any aftermarket HID kit that will fit the wattage for Fog light bulb.
Thank you!
philly001 is offline   Reply With Quote
Old 05-23-2011, 09:41 PM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
Originally Posted by philly001 View Post
Hello:
Thank you!
the 2011 fog light is a 2504 type bulb. This appears to be a brand new type or rarely use bulb, so I know very little about it. Other threads on this forum have found it to be a weird wattage like possibly 28 watts. All the reputable hid makers I know are not producing a 2504 HID kit yet. As to how to replace the actual bulb, given the 2011 is a revised generation I bet the replacement procedurte is different than my 2008. The Toyota manual should tell you how to get access to it (mine did).
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
The Following User Says Thank You to sweeneyp For This Useful Post:
philly001 (05-29-2011)
Old 05-27-2011, 08:39 PM   #3 (permalink)
Thank you!
Old 05-28-2011, 10:50 AM   #4 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
My 2011 manual calls for a 24 W bulb type E and the bulb number is not listed. Type "E" is listed as PSX26W (P.566).
On P. 489 to replace the bulb.. unplug the connector while depressing the lock release.. and turn the bulb counter clockwise..
A "Google" search on (PSX26W bulb) brings up this thread 2011 Highlander Limited White Headlight Bulbs Needed
Last edited by Ralph6410; 05-28-2011 at 10:54 AM. Reason: Added link to more discussion.
Ralph6410 is offline   Reply With Quote
The Following User Says Thank You to Ralph6410 For This Useful Post:
Old 06-14-2011, 09:15 PM   #5 (permalink)
View moemoney's Photo Gallery
2nd Generation HID Kit for fog light....
I too have a 2011 Highlander and I am in the process of installing the fog lights to HID once I get this week. I brought H16 HID kit with relay harness. You'll need that relay harness for the low-beam light too, if your planning to convert it to HID. I'll let you know sometime next week if that kit work or not.
moemoney is offline   Reply With Quote
Old 06-14-2011, 09:22 PM   #6 (permalink)
sweeneyp's Avatar
you don't need a relay harness for just fogs or low beams. I have my fogs running off stock wiring (35watt hid vs 55 watt oem) and I have two additional projectors behind the grill running off the original headlight power line (35 watt HID). My 55 watt HID headlights came with a wire harness due to the fact they are bixenon and required it to power the electromagnet in the bulb, but stock wiring can handle a 55 watt hid kit on its own. No wireharness needed
Old 06-15-2011, 07:00 AM   #7 (permalink)
Well i have try it without the relay harness and my hid 35watt from philips didnt work. So i decided to get a relay harness and install it and my hid kit work. My hid ballast have a built-in canbus to avoid error code, shock, flicking, and other short circuit protection. So im not sure what brand you got for your headlights but that good that yours dont need a relay harnesses.
Old 06-15-2011, 10:22 AM   #8 (permalink)
sweeneyp's Avatar
thats strange that a 35 watt wouldn't ignite on stock wiring. I ordered from DDMTuning and my ballasts do not have all those extra protection stuff, just a basic ballast, that might be it.
Old 06-22-2011, 02:36 PM   #9 (permalink)
Offical TN Vendor
XenonDepot's Avatar
Gameroom cash: $153300
View XenonDepot's Photo Gallery
H16 would be the same as 5202 meaning that you would need to get a 5202 HID kit.
Steve
ToyotaNation SUPER SALE is on now!! - SAVE $$$
AUTHORIZED Toyota Parts & Accessories VENDOR - SHOP WITH CONFIDENCE
XenonDepot is online now   Reply With Quote
Old 06-22-2011, 02:55 PM   #10 (permalink)
Steve
Well I did get the h16 kit and it turn out it is NOT made for the 2011 highlander. The fog light for the 20112011 highlander is psx26, which have a 3 pong twist in with 2 pin coennector. The h16 kit is a push in clip type that i believe it only use for 2008-2010the highlander...
Old 06-22-2011, 03:38 PM   #11 (permalink)
sweeneyp's Avatar
H16 is not used in 08-10 highlanders.
here are the bulb specs for those years:
H4 - headlight
H11 - foglight
Old 06-22-2011, 03:40 PM   #12 (permalink)
Offical TN Vendor
XenonDepot's Avatar
I'm not sure what kit you have but generally speaking we advise our customers that 5202 would require you to tap into your vehicle's headlight harness. The bulb should fit right in though.
Steve
Old 06-24-2011, 08:55 AM   #13 (permalink)
View inyadreems's Photo Gallery
See this link.
I was able to modify an LED bulb to work in the fog light housing. They look really good but offer no increased visibility.
inyadreems is offline   Reply With Quote
Old 06-24-2011, 11:38 AM   #14 (permalink)
Offical TN Vendor
XenonDepot's Avatar
thats the problem when installing LED bulbs in halogen designed housings Ie: DRL/Fog/ High beams. They look nice but offer very little light output.
Steve
