Power windows/sunroof continue to work after ignition is off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2011, 06:12 PM   #1 (permalink)
luck123's Avatar
View luck123's Photo Gallery
I just figured out today, only as a fluke, that the power windows and sunroof have power and are operational even after you turn the ignition to the OFF position and remove the key. However, once you open the driver's door (not sure about the others), game over...you need to turn the ignition to ON in order to power them.
Soooooooo many times, I have stopped the car and turned off the ignition only to realize that a window/sunroof was open. And what did I do every time? Insert the key and turn the ignition to ON again to close it, when all I could have done, is simply close the window!! Worse, it's probably in the manual!!
Official Bonehead Award goes to............................me!!
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
Old 05-24-2011, 07:15 PM   #2 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
That feature seems to have a timer built into it..
Ralph6410 is offline   Reply With Quote
Old 05-24-2011, 08:30 PM   #3 (permalink)
Dman1's Avatar
Gameroom cash: $135752
View Dman1's Photo Gallery
Yes. I believe that it lasts for 30 seconds.
And Luck123, yes, it is in the manual. When I first got my HL I actually had time to do things like read the manual...every page except for the sections on the DVD player and the Navigation system, since I don't have those. Now, with a five and a half year old running me ragged every minute that he is awake, it would take me years to read through the manual.
2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
Dman1 is offline   Reply With Quote
Old 05-24-2011, 08:35 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632150
Works on the Base model too.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 05-24-2011, 11:33 PM   #5 (permalink)
View dball711's Photo Gallery
I have a car that does this not on a timer but till one of the doors is opened.
dball711 is offline   Reply With Quote
Old 05-25-2011, 03:00 PM   #6 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535495
View 05Moose's Photo Gallery
Works on all Toyotas too (at least every model we've owned). Been this way for at least a decade! If you're sitting in your vehicle for that 30 seconds, you'll hear a click when it disables that feature. And if you own a model that has a lighted window switch on the driver's door, it stays lit until that 30 seconds is up (or you open a door). If you still need to adjust a window after it clicks off, turn the key to on and back off again and your 30 seconds begins again. This is like Toyota's automatic re-lock feature. That's another one I like.
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is online now   Reply With Quote
