Removing center console (front) from 08 HL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2011, 04:10 PM   #1 (permalink)
<Insert title here>
View YotaRunner4's Photo Gallery
Anyone know how to remove the center console of an 08 HL? I want to get access to the cigarette lighter power and I assume I need to remove the center console to get at it. Any advice?
'08 Highlander Limited 4X4, Silver Metallic
'07 Camry SE, I4 AT, Super White, Moonroof Package
'97 4Runner SR5 4x4 - Sold 1/2/09 with 164K miles
YotaRunner4 is offline   Reply With Quote
Old 06-15-2011, 04:34 PM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
Ive done this many times its faily easy, but first, which cigarette lighter are you talking about, the one near the cup holders or hte aux in?
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 06-15-2011, 04:37 PM   #3 (permalink)
RectangleAmericaMegaphone
View 9volt's Photo Gallery
Check the DIY thread at the top of the forum and look for the stereo install thread. It shows how to pull those panels. I believe you pull the small panel with the aux-in first.
9volt is offline   Reply With Quote
Old 06-15-2011, 04:41 PM   #4 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
This was discussed in this link. A quarter dropped into shift stick console!
Indications are it is easy.. but I had to give up for fear of breaking something. Let me know how you make out as I want to get at that wire as well.
Ralph6410 is offline   Reply With Quote
Old 06-15-2011, 04:45 PM   #5 (permalink)
<Insert title here>
I actually would like to know how to pull both consoles to get at each one. I just bought a switch and a relay so I plan on tapping the power off one of the two. Now I need to figure out where to put the switch.
Old 06-15-2011, 04:50 PM   #6 (permalink)
sweeneyp's Avatar
well the thread linked in a previous post is how you do it. you could always put the switch in an empty space on 1 of the two buttons on the center console (where the snow button is)
Old 06-15-2011, 08:27 PM   #7 (permalink)
<Insert title here>
I followed the thread above. Piece of cake.
@ Ralph - I started on the right side of the steering column. There is a little space where two pieces of plastic come together to get your fingers in. I grabbed it and pulled it towards me and all of the "snaps" started coming undone. 5 seconds later I had the entire AUX panel removed (panel where the seat heater controls and cig lighter is) after disconnecting the wiring harnesses. Once that is removed, the top of the center console comes right up. I was able to access the 12V supply for the cig lighter and feed that to a switch. Now I can control when the DVD headrests get power.
Old 06-15-2011, 09:07 PM   #8 (permalink)
Damn.. got to have another go at it.. Thanks
