Reverse + and - - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2011, 08:13 PM   #1 (permalink)
View Alterfalter's Photo Gallery
Reverse + and -
Does anyone know if there is an easy way to reverse the manual shifting option in a 2010 Highlander? To me the + and - just seem counterintuitive, so i end up shifting down when i actually want to go up one. Thanks
Alterfalter is offline   Reply With Quote
Old 07-03-2011, 01:33 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
Never heard of such an option. I did the same thing when I first got my Highlander, but like anything else you get used to it in short order.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 07-03-2011, 10:33 AM   #3 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535595
View 05Moose's Photo Gallery
Forget the plus/minus. Just learn to pull back when you want to slow it down in a lower gear. It's identical to all automatic transmissions. You always pull the lever back to shift to a lower gear.
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline   Reply With Quote
Old 07-03-2011, 08:06 PM   #4 (permalink)
View Evo[5.0]'s Photo Gallery
dont mean to hijack Alterfalter, but how can i learn how to drive using the + -? i never never drove manual
Evo[5.0] is offline   Reply With Quote
Old 07-03-2011, 09:05 PM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
I'll give it a whirl.
If you look down at your shift lever you'll see S-D just below the Neutral position. If your shift lever is on the right side of that detent then you're in Drive, and if you move it to the left you'll be in S-mode. When you put the transmission in S-mode it engages in 4th gear by default and you will see "4th" displayed just to the left of your odometer. Pulling the shift lever back toward the (-) negative symbol the digit will change from 4th to 3rd, then to 2nd, etc., each time you pull back. Pushing the lever forward toward the (+) symbol will progress into higher gears until your reach 5th. For reference, your owner's manual has similar information and diagrams. Hope this helps.
2002 Avalon XL
Old 07-03-2011, 10:17 PM   #6 (permalink)
ah i see. yea i notice when i first put the the car in s-mode it goes straight to 4th gear which i found odd. if the car isnt moving shouldnt it be in 0 or 1st gear
is there a advantage to driving in s-mode?
Old 07-03-2011, 10:35 PM   #7 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
Maybe when towing to keep it in 4th gear while towing on interstate to keep it from gear jumping too often.
I use mine mostly for holding speeds going down steep hills instead of cooking the brakes. Or if I see a red light ahead to gradually decelerate.
I've found the s-mode mostly just gives the car suggestions on what gear to be in, not force it to be in it. If you are stopped and put it in 4th, then it will change gears (starting at 1) while accelerating and stop at 4th gear.
If you downshift it will go to 3 if and only if it thinks your going slow enough (hence the mind of its own)
Now if you put it in 1st gear and floor it you will get (besides a lot of wheel spin off a stop...lack of grip on tires...) the engine to hit the redline and jerk violently, until you shift up. So it does work somewhat in that situation.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 07-03-2011, 10:39 PM   #8 (permalink)
Gameroom cash: $174015
View jgayman's Photo Gallery
I just don't understand the flirtation automakers have with these +/- manual shifters. Don't get me wrong, I've had plenty of manual shift cars over the years... 3-speed column, 4-speed, 5-speed, etc. but I've gotten to the point where I prefer auto.
I've tried manual shifting my '11 Highlander and a few other vehicles with the +/- setting and I've come to the conclusion that the automatic setting does a better job than I do at being in the proper gear at the proper time.
Besides, the engines are just so darn quiet you really cannot "feel" when to shift anyway.
jgayman is offline   Reply With Quote
Old 07-03-2011, 11:53 PM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
I'm not a control freak, but on the other hand I want to be able to make a better gear selection than the computer can do. On certain hills or grades I like to shift down to 4th (or even 3rd on very steep hills) and keep a steady pace instead of having the computer keep going back and forth between gears. Also, if I'm on city/suburban streets with 30 to 50 MPH speeds, I like to have it in 4th for better throttle response. In the end it's all about options, and I'd rather have the option to select gears myself instead of strictly relying on the computer.
2002 Avalon XL
Old 07-04-2011, 01:19 PM   #10 (permalink)
AML
Gameroom cash: $214800
View AML's Photo Gallery
Vehicles like Audi, VW, BMW, Porsche, etc. have their automanual controls reversed. They designed their automanual shift operations based on sequential manual transmissions used in race cars which downshift when pressed forward, and upshift when pulled back. It is more intuitive to pull back to upshift as the g-forces upon acceleration force your body back, and upon deceleration the g-forces force your body forward. To me this is much more natural than the way it is designed in Toyota/Lexus or other vehicles that do it this way.
In a normal everyday car like the Highlander, it is designed less to be used as a manual transmission mimic and more as a modern take on the traditional PRND4321 gear limiter for engine braking.
2011 Chrysler Town & Country Touring
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5 AWD
AML is offline   Reply With Quote
