Yesterday I used a can of evap deoderizer from Napa. Right now it does not smell but we will see how long that lasts. I tried to get the dealership to cover me on the TSB but they said they could never smell anything, then the warranty expired and I don't want to spend a bunch of time trying to fight them and possibly getting my dash torn apart and not put back together right.
Last year a local shop injected a foam cleaner thru the drain tube which cost me $85 and did nothing. I suspect it never reached the evap. That is why I want to drill the housing and clean it myself. I had excellent results with my Grand Cherokee, which smelled way worse than the Highlander. After I drilled that housing it was like a new car again. I fitted it with a rubber plug so I could repeat the cleaning every year.
If the smell returns within weeks that is exactly what I am going to do with the HL.
I'll probably just sign up the HL on alldata, hopefully there will be a diagram.
08 Highlander Sport 4WD
05 Chevy Express
02 F350 Powerstroke Diesel 4x4 Crew
87 Mercedes 300 Diesel
07 Tundra Dbl Cab 2WD 4.7 (son's)
