Exactly the same on mine - also a Curt hitch. I installed this alone, and all three bolts lined up on the passenger side, but only one bolt lined up on the drivers side. This activity took about 20 - 30 minutes.
Then I struggled with a steel bar and a 2x4 for another hour and couldn't get the other two bolts to line up straight. At this point, I just paid a hitch installer 20 bucks to put the remainder of the bolts in.
After the installer was done, I can see one spot with significant paint scarring - he must've used some heavy duty vice or chain to pull the arms of the hitch to line the holes up.
Good luck.
Originally Posted by rupert08
I have the Curt hitch (not sure on the part number). It was roughed up a little during shipping when I received it and 2 arms that mount to the vehicle were bent in a few inches. The rear most holes lined up okay but not the forward most holes. I was simply able to stand it up, put my foot on one arm and lift up the other arm so they were parallel again.
