2011 Highlander Garage Door Opener - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2011, 09:02 PM   #1 (permalink)
View Prettyboy Jake's Photo Gallery
Just brought home our 2011 Highlander Limited (Canadian Version). I've not been able to configure the garage door opener switch(s) on the top center console following the instructions in the manual. Garage door opener is a 2006 Sears Craftsman 315 mhz model 139.18458D.
Also, we discovered how uncomfortable the front head rests can be, pushing our heads further forward than we feel comfortable with (get headaches). Any solutions for an alternate headrest? thanks.
Prettyboy Jake is offline   Reply With Quote
Old 08-24-2011, 11:20 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
Perhaps this link will help. As for the headrests, I've got to say I thought the same thing when I first got my Highlander, but like so many things in life I got used to it after a while and don't notice it anymore.
BTW, to Toyota Nation!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
The Following User Says Thank You to TrailDust For This Useful Post:
Prettyboy Jake (08-28-2011)
Old 08-25-2011, 06:39 AM   #3 (permalink)
Thanks TrailDust! Will try it tonight.
Old 08-26-2011, 06:11 PM   #4 (permalink)
View bward76's Photo Gallery
I had this same problem with my wife's 2011 last weekend. I am familiar with the homelink system having it on my last two vehicles which have similar set up procedure.
My wife did get it working. I don't know what she did to get it to work. But as a heads up it was not intuitive to me even while reading the instructions!
bward76 is offline   Reply With Quote
The Following User Says Thank You to bward76 For This Useful Post:
Old 08-28-2011, 04:00 PM   #5 (permalink)
Highlander #2
Gameroom cash: $368567
View AXMACD's Photo Gallery
You have to press and hold the Homelink button and cycle the hand-held transmitter (open/close) until the light begins to flash rapidly. THen get out of the vehicle and press the learn button on the door opener.
2008 Highlander Sport V6 AWD, classic silver, black leather, Canadian version, 90 000 KM.
2009 Tacoma AC V6 4X4, SR5 w/ power package, timberland mica, beige cloth, 48 000 KM.
2002 Highlander Limited V6 4WD, black, tan leather, 134 000 KM (SOLD)
AXMACD is offline   Reply With Quote
The Following User Says Thank You to AXMACD For This Useful Post:
Old 08-28-2011, 04:08 PM   #6 (permalink)
got it to work after several different sequences of attempts. nice to have but a pain to set up.
Old 08-31-2011, 08:33 AM   #7 (permalink)
Take off, eh!
Dante's Taco's Avatar
Gameroom cash: $416240
View Dante's Taco's Photo Gallery
We just moved, so I had to do this (albeit on a first gen) & had forgotten how much fun it is.
Most if not all modern Garage Door openers use "rolling codes" so you will need to do this in 2 steps:
1) first your Home link in the HL has to learn the code from the actual physical garage door opener button which you hold 1-3 inches from visor while doing: This is detailed in the manual, but you basically pick which button you want to program on the Home Link, then press for instructed amount of time while pressing same button on garage door opener. When proper blinks sequence on visor occurs(I'm not going to post the one for my 2001, in case it's different for you 2nd gen guys), then your HL has learned the code. BUT you are not done, & this is where people go astray often.
2) now you need the actual garage door opener motor/receiver to learn the code. Climb ladder, find "Learn" button on garage opener box, press it, run back to HL - you have 30 seconds - and press & hold the visor button you just programmed. Usually something non-dramatic happens, like your garage opener lights flash once, or go on/off or out. If that happens, test it:
3) press newly minted Home Link button & see if garage door does something - but here's my other tip - you need to actually hold it in for like a second or two. These buttons aren't (at least on mine) ever the kind you just give a quick microsecond press & release. You have to seriously hold it for a full second before it does anything. I don't think everyone knows that...
Hope this helps others, since yours is up & running, or in case your wife (bward76) is on vacation & you change openers
Geoff
06 DC LB S45 4X4: Roll 'N Lock / Philips Xtremes / Cobra CB / AllPro IFS, tranny & T-Case skids,1.25 spacers, 10 pack leafs/ R. diff breather mod / fogs-on mod /Nitto Terra Grapplers 265/75/16 / Hakkapeliitta LT studded/ Timbrens / Fox CO + 2.0 resi x4 / YotaFab sliders / Yaesu FT2600
VA6TAC
Highlander LE 2001 (wife's)
Dante's Taco is offline   Reply With Quote
