Gel in Engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2011, 06:31 PM   #1 (permalink)
View Natalie235's Photo Gallery
Gel in Engine?
I have a 2008 Highlander Sport that has approx. 63,000 miles on it. Last week, at exactly 4 years after the purchase date I noticed smoke coming from my exhaust pipe. There was no noticeable change in the way the car was running, idling smooth and car was not running hot. Took it to my local Toyota dealer and was told that my engine has "gel" in it. Still waiting to hear if it will be covered under ExtraCare Protection. Has anyone else had this issue or heard of it?
Natalie235 is offline   Reply With Quote
Old 08-27-2011, 09:47 PM   #2 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
I wonder what "gel" is? After 63K miles any car will have oil residue (sludge) and any shop will be glad to offer to clean it out.. for a price. But gel.... and how that relates to smoke is up for grabs.
One can get something considered "varnish" (a deposit from gasoline) built up in your injectors which could cause them not to atomize the fuel very well.. and, which could perhaps look like smoke.. but you should notice a rough running vehicle when that is happening..
Ralph6410 is online now   Reply With Quote
Old 08-28-2011, 12:37 AM   #3 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Common to short trippers with infrequent oil changes.
I'd definitely get a 2nd opinion and some pictures. Don't trust your dealer.
BTW, a little steam out of the tailpipe is normal, especially if condensation built up.
deadrx7conv is offline   Reply With Quote
Old 08-28-2011, 01:37 AM   #4 (permalink)
Gameroom cash: $145500
View nogo's Photo Gallery
What colour smoke was it?
1997 Jetta GLS, 2007 E280 4Matic, 2010 Highlander Sport
nogo is offline   Reply With Quote
Old 08-28-2011, 09:45 AM   #5 (permalink)
View sonicboom's Photo Gallery
This.
Here is a good read.
http://www.synpsg.com/Oil_Sludge_Problem.html
sonicboom is offline   Reply With Quote
Old 08-28-2011, 10:04 AM   #6 (permalink)
Canada
Originally Posted by sonicboom View Post
A good description.. but perhaps a teeny bit biased. I don't think even Amsoil would guarantee a "spotless like new" oil pan after 64K. Still, a synthetic will likely stay cleaner than a traditional oil
Old 08-28-2011, 10:10 AM   #7 (permalink)
Haha yes, ignore the Amsoil product plugs.
Old 08-29-2011, 03:55 PM   #8 (permalink)
The "smoke" that was coming out of tailpipe appeared to be white, but after reading further into the whole "oil sludge" issue some call it blue. Anyways, it was not black smoke. And the car was running smooth, like normal. No change in idle or temp. We did check the oil and it was low, but no lights came on in dash. With as advanced as vehicles are these days, if my engine was about to die on me, shouldn't I have seen a warning light?
Old 08-29-2011, 04:25 PM   #9 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
with today's detergent oils, sludge is not nearly as much of a problem as days of old. unless you are abusing your car or waiting a LONG time to change your oil, sludge should never be a problem, regular oil or synthetic.
yeah, marketing tactics used by companies like amsoil love to blow the problem out of proportion, but it is a sales gimmick. amsoil is very good oil, but it is also very expensive and certainly not necessary for a daily drive that you take reasonably good care of.
amsoil spends most of their advertizing dollars at the race track, because in a high performance engine that is driven hard, synthetic matters. synthetic resists heat better and the best synthetics will break down less quickly and handle the demands/stresses that you put on your engine.
you should never have sludge in your daily driver that you take care of with the proper maintenance. i just dropped the oil pan for a gasket replacement on my wife's solara with 130K miles and the oil in pan was clean as a whistle, not a single trace of sludge anywhere.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 09-04-2011, 12:27 PM   #10 (permalink)
Gameroom cash: $183000
View Paul3637's Photo Gallery
Oil change interval? engine oil should never be low.
You did not mention the oil change interval. Toyota recommends 5000 miles or six months whichever comes first. Since you have over 60,000 miles on it in four years, at that rate you drive about 5000 miles in 4 months so only miles and not the passage of time should have been your determining factor. Your car also came equiped with a maintenance warning light that blinks at 4500 miles and stays on at 5000 miles until you or the person who changes your oil resets it. Please tell us how often you changed the oil, who did it, and whether or not you have the receipts. Also tell us who or how the warning light was reset when it came on ...... or did it come on and you ignored it? Even if you only followed the "old-pre sludge" oil change recommendation of 7,500 or 6 months .... that still should have prevented oil sludge or gel unless you were sitting in rush hour traffic for hours every day on the I-10. If the car was not properly maintained, the dealer may tell you the damage is not covered under the extended warranty .... same as if it had 59,000 and was covered by the original 60,000 powertrain warranty.
Your car is equipped with the 3.5L V6 (2GR-FE) engine. This technoloogically advanced engine is manufactured to close tolerences and is well known for (1) zero or close to zero oil consumption and (2) producing very little blowby (the gasses which cause oil to turn "dirty" and therefore cause the sludging and/or gelling of oil that caused the sludge and gell problem of the famous 1997 to 2002 oil related engine failures). The fact that your oil was low (just how low by the way - and was it milky grey or charcoal black?) tells me there could be engine damage from poor maintenance and/or the last place you took it only put in 5 quarts of oil instead of 6. The gel your dealer discovered pretty much confirms poor maintenance. Did they pull your cartride type oil filter element out and show you that it was clogged with sludge or gel? If not, they should have.
The only known problem with oil loss on the 3.5L V6 engine is the defective vvt-i oil line on cars built prior to April 2008 (for which there was a massive recall which included the 2008 Highlander). And ...... even when those lines "blew," some owners reported the oil light never came on even in cases where the motor ran out of oil and "froze."
You asked in your second post "With as advanced as vehicles are these days, if my engine was about to die on me, shouldn't I have seen a warning light?" The answer to your question is YES, sort of..... the car should be desinged to let you know at least when the oil level is dangerously low . but it is not. The oil light measures oil pressure, not oil level. By the time the oil light comes on due to low oil level, your engine is probably toast anyway.
I have the 3.5L V6 2GR-FE engine on my 09 Camry manufactured 02/08 and in 5,000 miles of driving before each oil change, the oil never moves off the full mark and still looks clean. My ex-wife has the same engine in her 2011 AWD Highlander SE (which is why I visit this forum) and it uses zero [synthetic] oil as well. [I just Googled 2gr-fe oil consumption or sludge and the only thing I get back is the aforementioned vvt-i oil line failure. If your Highlander has a build date of 04/08 or later, you should not have a defective oil line. If your car was built before that, you should have gotten a recall notice over a year ago and taken the car in.]
Good luck.
Last edited by Paul3637; 09-05-2011 at 02:31 PM. Reason: Dropred the used v new issue based on purchase date
Paul3637 is offline   Reply With Quote
Old 09-05-2011, 11:31 AM   #11 (permalink)
View jeffs3820's Photo Gallery
White smoke is indicative of engine coolant being burnt by the engine. Is the coolant low? A blown head gasket could cause this and account for some oil loss as well. Also, oil mixing with coolant will take on a "gel-like" appearance.
2008 Highlander Hybrid Limited; Nav, DVD (His)
2007 Volvo XC70 (Hers)
1999 Camry LE (mine, used by my son)
jeffs3820 is offline   Reply With Quote
Old 09-05-2011, 02:11 PM   #12 (permalink)
Head gasket - good catch but doubt that is it.
Except for the white smoke, hard to imagine head gasket ..... but maybe.
I found these as typical symptions at:http://www.associatedcontent.com/art...f_a_blown.html
Exhaust: White smoke coming out of your tailpipe. Sometimes drops of water will drop from the end of the tailpipe. The exhaust will also have a sweet smell to it.
Bubbles: Bubbles are also one of the signs of a blown head gasket. A gasket leak will cause bubbles of air to come into your radiator.
Oil: One of the next signs of a blown head gasket is contaminated oil. You will notice a milky ring surrounding your oil cap.
Engine: Engine will lack power because of compression loss. The engine will also run poorly and will idle roughly. You should also be careful because the engine will overheat quickly when you have a blown head gasket.
I posted in the bobistheoilguy forum at:
http://www.bobistheoilguy.com/forums...86#Post2367986
So it may be kind of interesting to see how it all plays out and if there is something you, me or the dealer hasn't thought of.
Old 09-05-2011, 02:52 PM   #13 (permalink)
<<*Exhaust: *White smoke coming out of your tailpipe. Sometimes drops of water will drop from the end of the tailpipe. The exhaust will also have a sweet smell to it.
*Bubbles: *Bubbles are also one of the signs of a blown head gasket. A gasket leak will cause bubbles of air to come into your radiator.
*Oil: *One of the next signs of a blown head gasket is contaminated oil. You will notice a milky ring surrounding your oil cap.
*Engine: *Engine will lack power because of compression loss. The engine will also run poorly and will idle roughly. You should also be careful because the engine will overheat quickly when you have a blown head gasket.>>
All symptoms above are true BUT many times are not obvious and sometimes so slight they are easily missed. I have had 3 different cars that had head gaskets go. In 2 of the 3 cases the car ran beautifully, didn't consume oil, but did consume coolant but VERY SLOWLY. Yes, there was occasional white smoke out of the tailpipe. There were no bubbles in the radiator and compression was good. With one car dealer finally found what looked like minor traces of water in the oil during an oil change and then replaced the head gasket. Second car had a TIB for coolant loss when cooling system pressure test was good. The third car did not run well and occasionally overheated.
Minor head gaskets issues can be tough to find on many vehicles.
