Airbag Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2011, 04:56 PM   #1 (permalink)
Highlander #2
Gameroom cash: $368567
View AXMACD's Photo Gallery
Airbag Problem
Last night I went and filled up my HL with gas, started it up and the airbag light has been on ever since. Theres a SRS message on the MFD.. have you had this problem before? What kind of warranty is this covered under?
2008 Highlander Sport V6 AWD, classic silver, black leather, Canadian version, 90 000 KM.
2009 Tacoma AC V6 4X4, SR5 w/ power package, timberland mica, beige cloth, 48 000 KM.
2002 Highlander Limited V6 4WD, black, tan leather, 134 000 KM (SOLD)
AXMACD is offline   Reply With Quote
Old 09-06-2011, 07:03 PM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
I've had this happen to me before with the whole message on the screen and what not. I pulled the negative terminal off the battery and let it sit for 20 min and put it back on and it reset the ECU. Hasn't appeared since. Mine came up when I was working on the speakers on my car, which definitely isn't airbag related
Hope this helps
EDIT: ignore, read below
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 09-06-2011, 11:56 PM   #3 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
According to Toyota's website, Airbags and seat belts are covered for 5 years or 60K miles in the US. If you live in Kansas, it's 10 years/unlimited mileage.
I thought that it was longer, but maybe Toyota changed their policy. This info is from their owner's info page. This is for a Toyota that was purchased new. Certified pre-owned may be different.
If your Highlander still falls under the warranty, I wouldn't pull the battery cables. I would have it checked at the dealer. Ask to know what code pops up, that way you know what it was, even if the dealer themselves just do a reset to clear the code. (That way if it pops up again you know it wasn't just a one-time fluke.)
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 09-07-2011, 12:23 AM   #4 (permalink)
sweeneyp's Avatar
I just remembered the active recall on select 08's. The B1E recall for the airbags. I am under this recall which is probably why my light has come on before. Is yours under this recall? The symptom for the problem is the malfunction light for the airbags coming up on the screen. I had completely forgotten about the recall, don't pull the negative terminal like I said earlier and have it checked
FROM TOYOTA's Website:
Safety Recall B0E (B1E - Interim) - Certain 2007-2008 Model Year RAV4 Vehicles and certain 2008 Model Year Highlander/Highlander HV Vehicles Curtain Shield Airbag (CSA) Sensor
Code: B1E
Memo
At the present time, Toyota is developing the remedy for this safety recall. As soon as a remedy is available, Toyota will notify owners of covered vehicles by first class mail. Please continue to check this site for additional information.
What is the Condition?
In the curtain shield airbag (CSA) system of the subject vehicle, there are two sensors in the airbag sensor assembly which are designed to detect vehicle roll angle. If one of these sensors malfunctions, the airbag warning light (Malfunction indicator Light: MIL) will illuminate and the roll detection system will be suspended; however, the airbag (CSA) remains available in the event of a side crash. If both sensors fail nearly simultaneously, the CSA and the seat belt pretensioner could inadvertently deploy upon vehicle startup (or within several seconds of startup) or during vehicle operation. Inadvertent deployment of the CSA and/or the seat belt pretensioner can cause injury to a vehicle occupant.
Old 09-07-2011, 06:21 AM   #5 (permalink)
summerwind's Avatar
Gameroom cash: $450530
View summerwind's Photo Gallery
I had to have the airbag computer replaced when this happened.
It requires removing the center console to be removed to get at it.
Was an all day process and covered under warranty.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 09-12-2011, 08:34 AM   #6 (permalink)
Highlander #2
A wire came loose under the passenger seat.
Old 11-28-2011, 12:31 PM   #7 (permalink)
View lispeej's Photo Gallery
I had this happen to me too and the dealer said that the main airbag computer had to be replaced. I thought it was a joke what they quoted me. They said that they'd have to reprogram my airbag computer too. Is there even such a thing?
There is a recall for it at this point, but Toyota hasn't found a fix for the issue yet.
lispeej is offline   Reply With Quote
