Side mirror lights - any way to increase the turn off delay?
After replacing the puddle lights with LEDs, I noticed that the duration of them being on after "unlock" is quite short (at least it feels shorter than incandescent ones).
Is there any way to increase that duration - meaning once you pressed unlock, the light to stay longer?
I suspect that LEDs are more sensitive to the voltage drop, i.e. they completely turn off much sooner in that dimming-off sequence comparing to the standard bulbs.
Will a large capacitor plugged in parallel to the LEDs help (by keep some charge after the power is gone for maybe few seconds)?
2008 Highlander Limited AWD Blizzard Pearl, Navi, removed charcoal filter, Philips X-tremeVision H4s, OSRAM HighBreaker Plus fogs, AVS bugshield and window visors, FIAMM dual horns, SteelCraft Bull Bar, LED reverse/all interior/side mirrors, stainless steel exhaust tip
