2008 Highlander Alternator replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2011, 12:04 AM   #1 (permalink)
Supercar's Avatar
View Supercar's Photo Gallery
USA 2008 Highlander Alternator replacement
I have to replace my alternator, does anyone know which amp i should purchase, 100 amp, 130 amp, 150 amp ? My highlander is a 3.5 V6 4 wheel drive, also, do I need to move the coolant hose that runs past it, or should I not worry about that. Thanks
Supercar is offline   Reply With Quote
Old 09-15-2011, 09:02 AM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
The stock is a 130 amp. If you got the towing package its 150 amp. Unfortunatly I have no idea about the hose that runs around it.
good luck
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
The Following User Says Thank You to sweeneyp For This Useful Post:
Supercar (09-16-2011)
Old 09-16-2011, 12:28 AM   #3 (permalink)
Supercar's Avatar
USA 2008 Toyota Highlander Alternator
Thanks a lot! I appreciate your help, do you think that putting a 150 amp alternator on now would be ok? even if i don't have the tow package on currently, but I plan on installing one. Or should I just install the 150 amp when I install the tow package? Thanks for the reply
Old 09-16-2011, 12:36 AM   #4 (permalink)
sweeneyp's Avatar
having the extra amps never hurts. I'd say go for it. I imagine Toyota used the same size wires (that come from the alternator) in all highlanders (130 and 150 amp versions), so you shouldn't have to worry about too much amperage going through too small a wire. Plus even if they didn't 20 amps is not a massive enough increase to really worry about.
Old 09-16-2011, 12:41 AM   #5 (permalink)
Supercar's Avatar
That makes sense, cool, thanks a lot, I really appreciate your help. Take Care
