tire pressure & engine oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2011, 09:25 AM   #1 (permalink)
View highlander123's Photo Gallery
come back to deal for a free oil change two time, the deal alway set my tire pressure at 38 psi (cold tire) and filled engine oil above max level and used 5-30w, Is that ok?
highlander123 is offline   Reply With Quote
Old 09-17-2011, 09:45 AM   #2 (permalink)
View guytdt's Photo Gallery
What year and how many cyclinders?
For 2011-2012, 4 cyclinders use 5-20 and 6 cyclinders use 0-20.
If you use 0-20, Toyota recommends change it after 10K miles. If 5-20w, then 5K miles.
So I guess it's ok, just change it every 5K with 5-20.
guytdt is offline   Reply With Quote
Old 09-17-2011, 10:00 AM   #3 (permalink)
2010 6 cyclinders toyota recommends 5-20w, I don't know why the dealer use 5-30w, I guess 5-30W is only one engine oil dealer have.
Old 09-17-2011, 10:04 AM   #4 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
the 08-10 use 5-20 (w/o towing package) and 5-30 (w/ towing package). you need to chance it every 5k with that type of oil.
The 2011-2012 use synthetic oil (not sure on the type, guytdt said though) and can be changed every 10k. Apparently synthetic oil helps them get a little more mpg out of the engine and change the oil less often since they do are doing the free oil changes now (to save money), so just be aware you have to change it at 5k and not 10k with regular oil.
About the max line, as long as they didn't really go over the max line you should be fine. If it's really over it, that can causes problems (leaks, gaskets issues, etc...). If you think its bad enough, you can always drain a little with the drain plug (could be messy though trying to put the plug back in while there is oil still in the engine.)
38 psi seems high for a tire in cold weather because as soon as heats up the air pressure is going to go up. I've never filled mine up past 33 psi and that is what my dealership always sets it up as.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 09-17-2011, 05:30 PM   #5 (permalink)
CPS Technician
View CPSDarren's Photo Gallery
I don't think the dipstick is real accurate. I just did my own change at 6 months. Manual said 6 qts. without filter. That's almost exactly what came out. At 5.5 qts added, it still reads around full on one side of the stick and way overfull on the other. I've driven it a number of times and same result. I think the 0w-20 maybe is so light it wicks up the tube or something more easily. Although the factory fill oil read normally, so maybe it just needs to get a little dirty or something I dunno. Either way, it's a lot harder to read than other cars I've had.
Mine: 2011 Highlander Hybrid (My Kids/Safety Review) - Hers: 2010 Prius II (My Kids/Safety Review)
CPSDarren is offline   Reply With Quote
Old 09-17-2011, 07:16 PM   #6 (permalink)
2010 highlander w/o towing package, but dealer used 5-30w, I asked them, they told me 5-20w and 5-30w is not much different.
Old 09-17-2011, 08:38 PM   #7 (permalink)
sweeneyp's Avatar
I wouldn't worry about it, its not a big enough difference to worry about. It has to do with the viscosity of the oil. If you were towing heavy loads regularly, it might try to get the correct one, but under normal conditions its fine.
Old 09-17-2011, 09:44 PM   #8 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535595
View 05Moose's Photo Gallery
And be sure to tell them about the tire pressure issue. They usually just have an hourly person doing the oil changes and it sounds like they don't know what they're doing on the tire pressures. Or maybe they're using a bad gauge (or yours is off? or is it on the paperwork that they set it to 38?). Anyway, they should be following what's on the door placard. While the tires can easily go up and over that pressure, there are some positives and negatives that go along with that. The positive is that you'll see better MPGs. The rest are all negatives: harsher ride (talking extreme pressures here not if they were set to something like 33psi), uneven tire wear, less traction, and longer stopping distances (critical in an emergency). So I would bring it to their attention.
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline   Reply With Quote
Old 09-18-2011, 02:49 PM   #9 (permalink)
Now - 2011 Explorer Ltd
peterk9's Avatar
View peterk9's Photo Gallery
38 psi seems too high in my opinion. As has been stated, you should follow the pressure recommendation listed in the manual and on label attached to the vehicle.
Lease Transferred - Canadian '09 HL Ltd, Classic Silver Metallic with Nav, ash interior, body side moulding, hood deflector, Camry trumpet horns, Philips X-Treme Power bulbs, Toyota 3 piece rubber floor and cargo mats. My 2011 Explorer Limited has arrived.
peterk9 is offline   Reply With Quote
Old 09-18-2011, 07:23 PM   #10 (permalink)
you are right, 38 psi is too high, I away set it back to 30 psi after go home. but I have went back dealer change engine oil three time, they set it 38 psi three time, I don't think that is a accident. dealer just want to blow my tires and buy the new from them.
Old 09-18-2011, 07:48 PM   #11 (permalink)
CPS Technician
If you don't notice an issue with ride comfort, 38 psi should be fine as long as it's not over the max sidewall inflation pressure. On my Dueler H/L 400s, the max is 44psi cold. Some SUV tires are as high as 51psi cold max. "Cold" commonly refers to the pressure at the start of the day before you drive it, rather than an absolute temperature. I run mine at 40-42 cold for fuel economy. Anywhere in between the recommended pressure on the door label and the max sidewall pressure is a tradeoff that is basically up to you.
Going beyond the max cold pressure (which is not a burst pressure) can adversely affect tire wear and possibly grip. Unless you're going for max fuel economy, the recommended pressure on the door frame label is probably the best tradeoff of all factors for most drivers, just be sure to keep it there throughout the year. You might find that 38 psi level in the summer ends up being about right in the winter if you are lazy like me, depending where you live;-)
Old 09-18-2011, 07:51 PM   #12 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
Definitely depends on how soft or hard you want your ride to feel. For me, 35 PSI has always been the magic number, with a compromise on ride quality versus gas economy and getting even wear out of the tires. My Duelers just passed 40,000 miles with even wear on all four.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 09-18-2011, 08:04 PM   #13 (permalink)
peterk9's Avatar
The factory recommended psi on my 2011 Explorer is 35.
Old 09-19-2011, 10:43 AM   #14 (permalink)
becks's Avatar
Gameroom cash: $126215
View becks's Photo Gallery
I run my 255/55 19's @ 33 psi year round in the NE, and rotate every 7-10k miles.
If I lived in Sunny/Warm Cali like TD I would probably run at 35 psi as well. I have tried 35 psi but, the cold winters here make it a stiffer ride.
08 4WD HL Limited, Magnetic Flint/Ash Leather, Toyo OC HT's 255/55/19's, European Horns, Extended Step Plate On Rear, DeBadged All Around. No NAV/DVD, OEM Hitch with Color Matched Fascia.Höen Endurance Amber Fog Light Bulbs.
__________________________________________________ ___________________________________
becks is offline   Reply With Quote
Old 09-19-2011, 11:00 AM   #15 (permalink)
Do you feel lucky?
TrailDust's Avatar
If you ran them as high as I do with that cold weather your dentist would have to replace your fillings shaken loose.....
2002 Avalon XL
The Following User Says Thank You to TrailDust For This Useful Post:
becks (09-19-2011)
